Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Noob help: recommend an aftermarket cooling option for Radeon 4850
Forum Graphic & Displays : Graphics Cards - Noob help: recommend an aftermarket cooling option for Radeon 4850
So the Radeon 4850 is all kinds of awesome, I already ordered one but I am concerned about the high temps it runs in (the only con on the card right now). What are some options to make it run cooler?
FYI: From what I've read, the cards screw holes are the same as the 3870 so if it worked on that card it will work on this one, but I don't know a lot about aftermarket coolers for GPUs to put it nicely. My mobo is the Gigabyte 780g micro-atx, my case is mid tower however, currently only has the 120mm fan that came with the Rosewill case.
Help a noob trying to get into PC gaming.
Sponsored Links
Umm, well id say double check to make sure it is the same as a 3870, then look at maybe an AC fan or similar
you probably want something that blows plenty of air and hopefully something that blows air out of the case.
http://www.newegg.com/Product/Prod [...] 6835186016
with
http://www.newegg.com/Product/Prod [...] 6835186021
they dont blow out of the case but should give a very good cooling performance.
Message edited by ninjaquick on 06-20-2008 at 05:30:27 PM
Reply to ninjaquick
- 0 +
I'm going to make my own. I bought a PCI slot fan that expels air out the back. I'll attach that to the exhaust of the card with some plastic and hopefully I'll be set. My card won't be here until Monday, though, so I won't know if it helps until then.
------------------------------ Phenom II X4 940 BE 3.0GHz - 1.25V > GA-MA790GP-DS4H > XFX ATI 4850 1GB > 4GB OCZ Platinum 1066MHz 5-5-5-15-2T > PCP&C 610W
Athlon II X2 250 3.0GHz > GA-MA770T-UD3P > Sapphire ATI 4650 512MB DDR3 > 4GB OCZ Platinum 1600MHz@1066MHz > XP/Win7 Enter 64
Reply to EXT64
There are 1224 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
