I am currently building my own PC, and I am not sure which Power Supply to get. However, I have found 2 which I like but I'm not sure which one I should get.
You're best bet is to stick with known brands so you don't fry all your precious innards. www.hardocp.com has a pretty extensive PSU test base, they have lots of good, bad, and ugly PSU's reviewed under their belt.
------------------------------e6600(3.0ghz 1.325v) on Noctua U12F,XFX 680i mobo, EVGA 640mb 8800gts, Modded antec 900 for CM, 1tb(2x500gb wd re2)+150gb raptor, Vista home premium 64 bit, mx 5000 K+M, dual sammy's 19(193p+)+22(226bw "s" ), z5500+HD595's, xfi plat, 850watt enermax Galaxy
Reply to eric54
that depends what components are going to be in your pc.... if its 2x 280's in sli then no , however for a more reasonable set up it is almost certainly fine
No, Just a 8600GT. Do you think it'll handle a Core 2 Duo E8200?
For a single 86000GT, the OCZ PSU will do fine. It provides plenty of power. Like Spuddyt said, if you were doing a SLI setup, it would be a bit short, for for one card, its just right.
------------------------------Evil lurks in the databanks as it lurked in the streets of yesteryear. But it was never the streets that were evil.
Over 50. Seen it, done it, can't remember it, but I miss it.
Reply to Sailer
