Tom's Hardware > Forum > Homebuilt Systems > New System Build > First Build: Final Review (please critique)
Forum Homebuilt Systems : New System Build - First Build: Final Review (please critique)
So this is the final parts for my build please check and make sure everything is compatible.
The only thing I have not yet decided on is the case.
Case: Antec 900 http://www.newegg.com/Product/Prod [...] %2bHundred
OR Cooler Master Stacker 830 Evolution http://www.newegg.com/Product/Prod [...] 6811119122
Is it worth the extra money to get the full size tower? Also, I like the look of the CM stacker better.
HD: Seagate Barracuda 500GB 7200RPM http://www.newegg.com/Product/Prod [...] 6822148136
MOBO: Gigabyte P35 http://www.newegg.com/Product/Prod [...] 6813128086
CPU: Q6600 2.4GHz http://www.newegg.com/Product/Prod [...] 6819115017
GPU: XFX 8800GT 512mb http://www.newegg.com/Product/Prod [...] 6814150252
RAM: Corsair 4GB DDR2 800 http://www.newegg.com/Product/Prod [...] 6820145184
PSU: OCZ GameXStream 700W http://www.newegg.com/Product/Prod [...] 6817341002
DVD Drive: Samsung DVD Burner http://www.newegg.com/Product/Prod [...] 6827151154
HSF: Cooler Master 120mm CPU Cooler http://www.newegg.com/Product/Prod [...] 6835103040
Thermal Compound: Arctic Cooling MX-2 http://www.newegg.com/Product/Prod [...] 6835186020
OS: Vista Home Premium 64-bit http://www.newegg.com/Product/Prod [...] 6832116488
Please review this build and tell me if everything is compatible and please help me make up my mind on the case :)
Thanks in advance for your help!
Message edited by efx92 on 05-31-2008 at 08:28:07 AM
Sponsored Links
The hard drive can be better try this
http://www.newegg.com/Product/Prod [...] 6822148288
I would wait on the GPU till the new ATI hit the market in a few weeks if you can not try a GTS here is one for the same cost as that GT
http://www.newegg.com/Product/Prod [...] 6814127325
Your PSU is ok but I like this one a tad better for the same cost
http://www.newegg.com/Product/Prod [...] 6817139005
And if your into gaming and not a big time OCer then a faster duo core will suit you better
http://www.newegg.com/Product/Prod [...] 6819115037
and for cooling look at this one
http://www.newegg.com/Product/Prod [...] 6835233003
Message edited by HoustonSerenity on 05-31-2008 at 09:25:12 AM
------------------------------ Robert Wilensky:
We've all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true.
Reply to HoustonSerenity
Ok, thanks. Any other opinions?
Reply to efx92
Both cases are good, but the 830 Stacker has been out for over 2years. CoolMaster has 2 other cases you should check out and also Thermaltake have 2 new ones out also that you should look at.
COOLER MASTER cosmos S RC-1100-KKN1-GP Black Aluminum ATX Full Tower Computer Case - Retail $249.99
http://www.newegg.com/Product/Prod [...] 6811119150
COOLER MASTER COSMOS 1000 RC-1000-KSN1-GP Black/ Silver Steel ATX Full Tower Computer Case - Retail $199.99
http://www.newegg.com/Product/Prod [...] 6811119138
Thermaltake Xaser VI VG4000BWS Black / Red Aluminum / Steel ATX Full Tower Computer Case - Retail $239.99
http://www.newegg.com/Product/Prod [...] 6811133052
Thermaltake ArmorPlus(Armor+) VH6000BWS Black Aluminum / Steel ATX Full Tower Computer Case - Retail $204.99
should be back in stock 6/04/2008
http://www.newegg.com/Product/Prod [...] 6811133056
also at www.performance-pcs.com for $199.99
http://www.performance-pcs.com/cat [...] s_id=23113
and then there is the Antec Twelve Hundred Black ATX Full Tower Computer Case - Retail $214.95
but it is out of stock until 6.20/2008
http://www.newegg.com/Product/Prod [...] 6811129043
So there you go, these are the best full tower cases out now. Hvae fun deciding!!!
Reply to Yoosty
I'd check out the Antec twelve hundred also (the 900 is great) and look at the in-depth reviews of the Xaser - it looks pretty cool too.
The Antec case was cheaper and in stock at Microcenter a week or so ago, so you can check there too.
The PSU you had was intended for SLI - it's a little more power than you'd need for only one GPU - you could probably get one with less output.
Reply to huron
your set up is pretty nice, but i would upgrade the hd to 7200.11 32mb cache seagate 500gb.
ram ,psu, gpu look good
Reply to godless
Go with the ocz its better in my opinion.
Reply to alfrido
for gaming use e8400, i did & 3d mark (at stock) jumped from 11.000 (e4500) to 19.000 (e84) & when oced 13.090 to 21.k sumthing using e84
Reply to spotless
Go with this one.
its actually a 670 wattage. And when you buy it they tested it out for you already you get a paper that shows you. Its silent. Cables are long and can fit those huge towers. And the best brand.
http://www.newegg.com/Product/Prod [...] 6817703005
Reply to alfrido
But how does one oc a 8400 on a gigabyte ga p35 ds3l with a Artic cooling pro. Message me if you do know.
Reply to alfrido
alfrido wrote :
Go with this one.
That's a killer price on on that Silencer610
The same as you OC a Q6600, You might need to increase voltages to get the same percentage of OC though, I haven't looked at it.
Reply to Zorg
Ok, what's the difference between the Thermaltake Armor and the Thermaltake ArmorPlus?
Reply to efx92
Also, I went with the E8400 and the 32mb cache HDD after so many people recommended it even though I wanted to somewhat future proof the CPU with a quad core :P
Message edited by efx92 on 05-31-2008 at 07:43:34 PM
Reply to efx92
Bump. Still can't decide on the case =/ I still really like the look of the CM Stacker but is it just too old of a case now?
Reply to efx92
Hey efx, nice original build.
It's not so much that the CM Stacker is too old, its just that the newer cases are more efficient and ergonomic, and your probably going to get cooler system temps, and in turn better airflow from the newer cases.
However, at the end of the day it's your rig, and if you like it go with it.
I would change that HDD to a WD 5000AAKS if you can afford it, great HDD and not so expensive.
I also agree that you should hang tight for the benchmarking results of the new ATi and nVidia cards during the next few weeks, while the 8800GT is a reasonbly cheap solid performer, I think this new gen of cards will really benefit you price / performance wise.
Hope I helped!
Reply to p0isonapple
I think I'm going to go with the 8800GT for now and then wait like 6-8 months to upgrade it and the prices on the new ones should be down by then.
Reply to efx92
Yeah, well i'm pretty much playing the same game as you, except i already have a Q6600 8800GT system right now, i'm going to wait till x-mas and spend about $3500AU on a new high spec rig
Nice, wish I had that kind of budget :P I only have $1500 for the desktop and then $500 for my monitor,keyboard,mouse, and speakers so $2,000 total.
Reply to efx92
Haha, well i can tell you with that rig your getting above your going to get very nice performance out of it, even with that Q6600 on stock speed and the 8800GT. Are you gonna overclock your CPU?
I'm thinking about it but, like i said, it will be my first ever build so I just want to make sure everything works before i even think about overclocking lol but I'm still going to get a CPU heatsink/fan in case I do OC it in the future.
Reply to efx92
Yeah good idea, my new rig coming up in x-mas will be my first ever OC'ed one, but i'm going SLi GTX280's so I think I need to overclock not to bottleneck them.
You're going to be happy with your rig but, and i've been reading about that CM 830 Stacker, and it's a great case mate, you will definantly be happy with it, will also come in handy for that big 120mm cooler which you also made a really good choice on.
Awesome, thanks for all the help p0ison, appreciate it :)
And I bet those new cards will be awesome in SLi, lucky you.
Message edited by efx92 on 06-01-2008 at 03:17:25 AM
Reply to efx92
Haha thanks mate. Goodluck with your system buddy i hope you enjoy it. :D One last question, where abouts will you be placing your rig?
I'll probably be building a shelf next to my desk because I don't think my desk will hold it haha
Reply to efx92
Haha yeah, I was just gonna say make sure you check those dimensions cause that 830 CM Stacker is a big unit! haha
I went to Fry's Electronics today to check out cases and it is pretty huge but it's nice looking
Reply to efx92
Yeah, also I would almost put money on the fact that you would need to mod the Antec 900 to get that beasty CPU cooler in. What is your current rig setup?
Right now, sorry to say, but I'm using a Mac..lol
I got it because I do a lot of video editing but now I'll have my mac just for that and my new build strictly for gaming.
Message edited by efx92 on 06-01-2008 at 03:42:15 AM
Reply to efx92
And I decided to go with the CM stacker so I think I can fit the cooler in.
Reply to efx92
You're going to REALLY love this rig then haha!
Well goodluck buddy make sure to PM me when you get it telling me how it is. :D
Will do, my friend is going to help me build it and he's built a pc before so I hope it works out cool, you have AIM or something?
Reply to efx92
yeah, sure do mate.
AIM: p0isonapple
MSN: p0isonapple@live.com
just gotta re-install AIM so give me 2 mins :lol:
sorry my screenname is p0isonappleAU go ahead and add it :D
There are 821 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
