Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How much power do I need for an E8400?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - How much power do I need for an E8400?
Can anyone tell me how much power I would need (amount of watts) fro an E8400 with 2 gig ram on a sysytem not intended for gaming/ overclocking or any video editing/ coding???
Sponsored Links
Why do You want E8400 on a system not intended for gaming/ overclocking or any video editing/ coding?
Anyway we are going to need more specs of Your sytem to help not just a cpu.
Reply to ainarssems
I would grab this.
For $30, It's tough to get such a good quality PSU.
Even that, however, would be overkill for wattage.
A decent 300w PSU would be more than enough.
If you really are only going to be using low end GPUs, even this would work.
http://www.newegg.com/Product/Prod [...] 6817371013
However, that is a lower end Antec model and I would go for the 1st one.
------------------------------ If its good in theory but not in practice,
its not good theory.
Reply to zenmaster
thanks zenmaster, (your first link didnt show up though)
ainairssems - cpu is for ultra quick vista use/ general tasking and "yes I can notice the diff from say 2.4 ghz" - am looking at an Intel G31 ICH7-DH mobo b/c it's cheap and will do the job + has an 1333 FSB, I'll use a WD CAVIAR 640gb for the HDD, Ram will be lo-end Corsair DDR2 667, I will do some DVD burning and yeah is that enough info for you?
Reply to simon1980111
oh sorry, forgot to mention - no graph card at this stage unfortunately as I've been led to beleive it wont imiprove performance for int browsing/ downloading DVD's, and since I'm not gaming what's the point?
yeah supremelaw I had a 430w earthwats tagged as the psu, but am hoping to shave off some cost by downgrading b/c probably no point having some much power when not overclocking/ gaming
A discrete graphics card like a 2400Pro can offload some of the video processing and can improve the quality on DVD video.
Don't some of the integrated ones drop frames?
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
dont really know, i might need one of those 2400 things
thanks Paul, I might get a lo-end 250 watt corsair and hope for the best, cheers
The Ancte 430w was the one I had linked.
If you want to go lower, get the Basiq, which is only $19.99 plus shipping.
If you try and shave any more price off, you will not be getting a quality PSU.
However, The 430w Antec will likely pay the difference in price due to the higher efficiency. You can try and find Antec Case/CPU combo deals. You may find really good deals to save you money. Most of the Combo deals have the EarthWatts which are 80+ Certified and good quality.
Reply to zenmaster
Here an an Example -
http://shop2.frys.com/product/5420 [...] IN_RSLT_PG
I bought this case on sale for a steal of a deal a few months ago.
It's a nice case and CPU for builds that will not be using lots of power.
Reply to zenmaster
i would do a minimum dual 1000w psu's.
Reply to ifor
minimum 2000 watts wtf! that would power my whole house (I'm not OCing so I think that would be a waste of money), thanks anyway
relax, it was a joke.
Reply to ifor
actually, id go for a decent psu over 400 watts to be safe.
I could use something liek that in my rig, since it needs about 300 watts. But just to be safe, go for something larger within your budget.
Reply to rabidbunny
There are 1168 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
