Hey all! First time poster here. Im building a PC with money I got from my graduation and would like input/advice from the wise users here. I am purchasing everything from newegg and would like to keep it cheap, under $1500
Case: I am interested in the Antec 900, but I have heard that it may have space issues, though its cooling is very attractive. Any other recommendations are appreciated.
PSU: a Corsair 650W should be enough, shouldn't it? And is fairly cheap at $110.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
CD/DVD: no idea what I should get. So long as it burns DVDs/CDs.
Hard Drive: 250G Seagate Barricuda w/ 16mb cache.
Mobo: the gigabyte EP35-DS3L looks great.
CPU: Is the 45nm Q9300 worth $50 more than the Q6600? Or should I just stick with a dual-core?
Memory: 4gb of ddr2 800. I'm looking at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145194
Video Card: Evga 8800GT2 $230. I see that evga has overclocked versions. do these all have the same coolers? Could I easily overclock the card to be equal with the more expensive versions? I will step up to the new nvidia card when it comes out.
OS: Vista 64bit. Is there a reason that I should get ultimate rather than basic?
Monitor: I am in need of a nice widescreen monitor, preferably about 19" because I'm gonna be in a college dorm and need space. I plan to play on high resolutions and was looking at this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001094
I don't know much about brand reliability and such, so feel free to recommend something completely different.
Is there anything I am forgetting? All help is appreciated, and I will be checking back here frequently to collaborate with you.
