Tom's Hardware Forums » CPU & Components » CPUs » Need final advice for new components!
Word :   Username :
Bottom
Author
 Thread : Need final advice for new components!
Profile: enthusiast
More Information
Motherboard
CPUs x2
Ram x2
After exhaustive research I decided this setup will best meet my MEGATASKING PLATFORMANCE needs!
Related Product
Profile: old hand
More Information
Looks like a good setup. You're pretty well futureproofed with that rig.
Profile: Honorary Poster
More Information
I think you should swap that Motherboard out for this:
http://www.newegg.com/Product/Prod [...] ll%2btrail
With that, you get both SLI AND Xfire.
http://i62.photobucket.com/albums/h82/TXSuperFly03/478x88copy.png
Profile: enthusiast
More Information
I don't think so with that I can't have 12 hard drives!
Profile: Ancient Poster
More Information
HAHAHAHAHA..........
Quad FX......
I think I have read that AMD plans on bringing it back too....
http://valid.x86-secret.com/cache/banner/381014.png
More Information
Don't worry about HDD. You should really take a look at Solid State Drives... real bang for the bucks.
Profile: newbie
More Information
I wish my rig was that awesome. I am still running a Sempron 2800+ S754 with an 8400gs.
Profile: nimble knuckle
More Information
Why waste money on FX-74s? Just get two FX-70's, they overclock better too. The magic voltage for OCing is 2.3V.
Profile: enthusiast
More Information
Yes. This should be an awesome QUAD FX setup. Do you think the Huntkey 450W power supply I ordered with it will be enough to keep it all powered up reliably?
More Information
I think 450W is too little. Maybe you should look at one of these:
http://www.newegg.com/Product/Prod [...] 6817101033
More Information
Ummm.... 450w...... Imma go with no since the CPUs themselves take more than half that when under load :P
That and wow they still charge that much per CPU?
Profile: enthusiast
More Information
I compromised! I ordered two FX 72s and I will overclock them to the 3GHZ of the FX 74. This setup should destroy anything else out there.
kad
Profile: addict
More Information
I do not know why you are going for Server mobo
But stay away from Skulltrail mobo Intel BOXD5400XS
And with this setup I was expecting to see 8G RAM not 2G only !!!
Message edited by kad on 07-14-2008 at 09:49:42 PM
LianLi PC-A70 Case/Enermaqx Galaxy 1000W/Asus Rampage Formula/E8500/Thermalright Ultra 120 Extreme Lapped/Scythe S-Flex SFF21F/Crucial Ballistic Red Line DDR2800 PC6400(2X2)GB/8800GTS 512MB/WD Raptor2X150GB/ViewSonic VX922(1280X1024Max)
Profile: enthusiast
More Information
Well fine then. I'll get the 2000W power supply if you think that is best. I'd hate to run out of power and have an unstable system.
Profile: enthusiast
More Information
It is not a server motherboard, it is a motherboard for the QUAD FX platform for megatasking.
Profile: newbie
More Information
A sweet system like that would really fly for when you are encoding any home movies. but I do think you should go with at least 3gb of ram....just buy another stick and put it in.
Profile: addict
More Information
