AzureFlameXIII :
So im getting some computer upgrades to help me play Crysis. (im on a budget so don't mock my purchases)
-Intel Pentium Dual-Core E5200 Processor
-OCZ DDR2 1150 MHz Reaper HPC Edition 4GB Dual Channel Memory
-GeForce 9400 GT
Can someone tell me a how-to guide or a video on overclock these components to play Crysis on a good frame rate and high quality. Thanks A Bunch Guys
If you already have the e5200, you can safely overclock it to 3.32 GHz (12.5 multiplier at 266 bus). I play Crysis on an e4500. It was was 2.2 GHz stock but I run it at 2.92 GHz (11 times multiplier at 266 bus) on the stock Intel heatsink fan. On High settings, I get around 21 FPS avg on a 19" widescreen at 1440 X 900 resolution and thats with an older 8800 GTS 320 mb version .
Your e5200 if overclocked is sufficient to play Crysis. You may be able to overclock higher with the e5200 but you'll need to replace the stock Intel heatsink cooler. I had an old 8500 GT equivalent to your 9400 GT and I played Crysis on that but at low and medium settings on 1024 by 768 resolution. It was okay and I got into the gameplay but the experience is much better with the visuals and eye candy on high settings which means you'll need a better video card and with that at least a 400 watt power supply. Even if you overclock your 9400 GT you might get a 2,3, or 4% increase on frame rates which is not a noticeable improvement. That card just doesn't have the muscle to play Crysis beyond low settings.
If you're a gamer believe me it's worth the upgrade just for $25 more for a better video card. You can find open box 9800 GTs on Newegg from $79 to $90 on certain days when they update their stock. I'm a budget builder too and over the last year I purchased 2 open box motherboards and 3 open box videocards with no problems at all.
For $51, maybe get a 9500 GT?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814134052R
For $66 maybe a 9600 GT?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127382R
And if you have more on your budget then go for the 9800 or GTS 250. But if you do you'll need a better power supply. I hope this helps you.
