ok, i know that RAM speed is usually based off of the FSB, but mine seems to have decided to go off of the cpu. (cpu/6) my friend won't believe be no matter how much math and proof i give him. he has it in his head that he ram decided to configure itself to my cpu's multiplier and derive the speed from some sort of equation that changes whenever i change the FSB. so i decided to try and get your help to put a RPG up his ***.
things that matter
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231098
CPU: AMD 4400+ brisbane
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813135075
after i noticed in cpu-z that the FSBRAM box said cpu/6, i decided to change my FSB to see if it was true like anyone would (i would think anyway). and it has only proved to be correct.
im afraid that my internet is being odd today, so i wont be able to give you my cpu-z pics, but i will give you stats
current
core speed: 2504.6 MHz
multiplier: 11.5
bus speed: 217.8 MHz
Hyper transport link: 1089MHz
memory
DRAM frequency: 417.4MHz
FSBRAM: cpu/6
past
core speed 2300 MHZ
multiplier: 11.5
bus speed 200MHz
Hyper T: 1000MHZ
Memory
DRAM frequency 383.3
FSBRAM cpu/6
anything in between always yielded the same results. core speed/6=DRAM frequency while DRAM/FSB= i cared not to really remember.
so if you can help me prove him wrong some more, it would be of some help. (its really odd of an atheist not to listen to math/science)
things that matter
current
multiplier: 11.5
memory
FSBRAM: cpu/6
past
core speed 2300 MHZ
multiplier: 11.5
bus speed 200MHz
Hyper T: 1000MHZ
Memory
FSBRAM cpu/6
