Tom's Hardware > Forum > Storage > Optical Media > Blu-ray problems
Blu-ray problems
Forum Storage : Optical Media - Blu-ray problems
For starters, i'm not sure if this is the right area to be posting this... it seemed the best @ the time...
I recently bought an internal Blu-Ray drive for my Vista x64 PC. http://www.newegg.com/Product/Prod [...] 6827106326
It installed fine, and it came w/ Cyberlink's PowerDVD 8 BD edition
When I insert a BD disk, it runs w/o sound for about 2 minutes, then the picture freezes. The display timer continues on the screen, but i can't click on anything (2 minutes isn't long enough for the menu to fully pop up)
does anyone have any ideas?
oh, btw. Normal DVD's work just fine.
My computer is:
AMD: Athlon 64 X2 5200+ 2991 MHz
Mobo: Gigabyte M57SLI-S4 v.2
RAM: 4GB Mushkin DDR2 PC2-6400
OS: Vista 64bit SP2
VC: EVGA 8800 GTS 320MB
Message edited by arges86 on 09-17-2009 at 06:59:47 AM
Sponsored Links
Video card and monitor have to be HDCP compatible also.
Test that your PC is ready to play Blu-ray Discs
http://www.cyberlink.com/english/s [...] gnosis.jsp
Reply to evongugg
i've run that test before i bought the optical drive
(the test was also on the PowerDVD software as well)
it says everything is OK for BD
Reply to arges86
Test the memory with memtest86+.
Tell us about your power supply.
Reply to evongugg
memory is fine
PSU is a BFG 800 Watt ES Series
Reply to arges86
Give anydvd a try, they have a free 21 day trial
http://www.slysoft.com/en/download.html
Also does your Lite-on have the latest firmware installed.
Message edited by RetiredChief on 09-18-2009 at 09:17:06 PM
Reply to RetiredChief
There are 466 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
