Yes No
Ads
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Help me with the **** Stuttering!! please!!
Forum Graphics & Displays : Graphics Cards Help me with the **** Stuttering!! please!!
Hello guys, something is not working well in my PC. I,ve got this pc since 6-8 months ago, I tought it was a problem with my graphic card, or just a common problem with this generation of GPU with the unified shaders. BUt this is unaceptable.
- The screen, when is moving arround, it dont go smooth, The entire scenary jumps again and again, like Plop ... plop.... plop, every half second or so. FRAPS can still showing 60FPS but the screen jumps all the time. This looks like is only happening when the screen is moving arround, not when the camera stops, the animations in the game looks fluid. It hapens with all settings in all configurations, in all resolutions, in some configurations "seems" going better but it still there. VSync On and of triple buffer on and off.
PC Settings
*C2D E4400 @2,6 (266x10) 1.2v - (Stock and 1.3v same problem)
*Asus P5K p35 (Upgraded Bios today, the problem still here)
*2GB Ram Geil DDR2 800 2.1v (1,8-2.2v and 600/850@ same problem)
*Geforece 8600GT 540/700 OC -> 700/950
*PSU Corsair Vx450 ( i had another psu and same problem)
*Sound card Terratec 5.1 Fun.
Temps are ok, i got Artic cooling 7 pro for CPU, and Zalman VF900 for GPU.
*Windows XP 32bits SP3. Installed, formated HD, a lot of times.
I spended money to buy it working, not for spend time and pacience to see what the hell is, because some people dont do his work. Microsoft, Nvidia... frustrating.
Reply to Alatriste
You using a widescreen LCD for your display? If possible, you may need to disable LCD overdrive in your drivers control panel. Otherwise the system is fairly sound, depending on what res you're running at the 8600gt may be holding you back.
------------------------------ AMD Phenom X4 9850 Black Edition, ZeroTherm Nirvana 120 Premium CPU Cooler, MSI K9a2 Platinum bios 1.1b3 or P.0J, 4GB (2x2) Mushkin DDR2 1066 (pc8500) 5-5-5-15 2.05v RAM, Sapphire Toxic HD3870, Raidmax RX-700SS PSU, Seagate Barracuda 7200.10 320gb SATA2 X
Reply to Mathos
Yes, widescreen 20" 1650x1080. LCD overdrive?? never heard that before.
The gpu is not holding back because this hapen with 60fps+. Even when you have 10 fps if they are stable, they only jump between eachother, not every 0.5 secs.
Reply to Alatriste
This has happened to me with my 8800GT in some games.
I solved by setting the "Maximum pre-rendered frames" in the Nvidia control panel to 1 instead of the default 3, and turning on triple buffering (even though the games this happened in were not OpenGL).
Try it and see if it solves your problem.
Reply to trackman2010
- 0 +
VF900 for a 8600GT? You actually bought DDR2 800 despite the negligible performance increase rather than a better GPU (which would make a huge difference)?
Reply to modtech
After trying the suggestions others have posted, my 2 cents is that if you want to game, you really need a better GPU. An 8600GT is a very low end gaming card.....any gaming enthusiast would not even consider it an option.
An 8800GT is what I would call a minimum GPU for decent gaming performance these days.
Reply to jitpublisher
Message edited by Alatriste on 06-22-2008 at 10:37:30 PM
Reply to Alatriste
When i bought the 8600GT, my options were: Ati x1950pro for 120€, 8800GTS 320MB for 270€, and 8600GT, 2600xt, 7900GS all for 99€.
7900gs no shaders, 2600xt no rops no texture units for low end useless, x1950pro more expensive older arquitecture, more power compsuption, and i tought that it would re-sell worse. 8800GTs no coments. So i think i did the best choice. Not to mention the great OC that puts 8600gt together with 8600gts.
I tryed now Call of duty 4, and it runs smooth in some places when moving the screen arround (with dual gpu option enabled or something like that) but when you look trought some kind of object, like barrels stuttering hapen. This is despite the frame rates, so this is not because my gpu is not powerfull enought.
Warcaft 3, old game when i move the screen it stutters, all time, anywhere, doesnt matter how long ive been looking into some place. (so no HD problem, or memory etc.). I ll try with some game without Transform and lighting, to see what hapen.
Trackmania forever, when im at grass, far away of the circuit, and im doing driftings in circles, the screen jumps rithmically even if fraps is displaying always more than 60 fps.
Message quoted 1 times
Message edited by Alatriste on 06-22-2008 at 10:45:49 PM
Reply to Alatriste
- 0 +
lower your resolution an 8600 cannot supply those rez's you need an 8800 or better for 20" and up,8600 is the pci-e version of the 7600 agp <> ,,if you can return that sucker and get the 8800,you'll be glad you did...:) :bounce:
Reply to dokk2
too late i think, just wait till nahalem then upgrade everything.
------------------------------ Do not fall prey to perceived obsolescence.
Reply to DarthPiggie
Dude i think i know ure problem ..Have you got the latest drivers..If you have overclocked your CPU .....or the GPU
I had this problem ..it had turned out to be corupt video driver files...try OMEGA Drivers . Let me know if any of these solve your problem.
Reply to slashzapper
I installed windows many times, and installed a few diferent drivers. Forceware 169.21
Message edited by Alatriste on 06-23-2008 at 04:46:47 PM
Reply to Alatriste
http://www.mediafire.com/?m0ezjpodxdz
Uploaded videos of call of duty 4 and warcraft 3. Both had +60fps all the time, and the screen still jump and freeze. Call of Duty have the dual card option enabled.
Reply to Alatriste
- 0 +
Isn't that a crazy oc for a 8600? Tried default clocks? Why do you have dual gpu enabled in cod4, are you running sli?
Message edited by stemnin on 06-24-2008 at 02:03:48 PM
------------------------------ Yep, I was here before Al Gore invented the internets.
Reply to stemnin
Stemnin, the overclock is ok, is stable. It can run at 740/1020 3Dmark but it crash sometimes since i put VF900 cooler. Maybe like this cooler is not working on memory modules, they are heating up??.
And yes at default clocks it got the same problem, but oced gain 30/35% performance :DD. But it can run 60 fps and still not enjoying the game :((, help pls!! anyone is in the same situation than me???
Dual gpu option, it fix the stuttering in this game, dont ask me how it works, because i dont know. (in my case it just fix a little, but still)
Reply to Alatriste
help PLEASEEEEEEE
Message edited by Alatriste on 06-26-2008 at 05:49:13 AM
Reply to Alatriste
I tried everything, please need advice of someone who have the same problem.
Reply to Alatriste
- 0 +
When your system slows, is your Hard Drive churning??
------------------------------ Trying to make up his mind whether the current situation is due to an overabundance of high quality pharmaceuticals freely available on the Internet. ...or not enough of them.
Reply to Scotteq
This is not HD problem. The video show it. Arround the same object in the same screen, with no loading in HD, and no loading memory nothing.
Reply to Alatriste
I did some research, and i found something about voltage regulators being too hot on motherboard, or graphic card. Causing system inestabilities.
How can i measure this?? P5k is not supposed to work without cooling, can i RMA it??
Reply to Alatriste
The 7900GS trashes the 8600GT DDR2 and beats the GDDR3 version most of the time in case you didn't know.
Try bringing everything back to stock. No overclocks. It's worth a shot.
EDIT: ^Nevermind.
Reinstall drivers?
Message edited by doomsdaydave11 on 07-03-2008 at 12:01:44 AM
------------------------------ E8400 3.6Ghz | 4GB DDR2-800 | HD4870 | 780GB HDD Space | VX550W | WinXP | Win7-64 | Ubuntu Studio 8.10
Reply to doomsdaydave11
7900GS is less than half fps of 8600GT, dont talk about ocing. Its shader power is ridiculus.
I reinstalled windows and formated HD, and tryed some drivers beta and non beta, ofcourse they were nearly newest to the date.
Im looking to voltage regulators, can this be the problem??
Reply to Alatriste
- 0 +
You realize that the 7900GS has no universal shaders because it has vertex and pixel shaders (separate), right?
The 7900GS will outperform the 8600GT in most games, it is simply a fact (see here).
Reply to cjl
Do something, buy 7900GS play Call of duty 4, Unreal tournament 3, Gears of War, Team fortress 2, Trackmania forever, after buy 8600GT and see wich card show more fps.
If not you cant talk. 7900GS is a very bad arquitecture now (does not have today games in mind)
And how the hell you show me a comparative where 7600GT outperforms 8600GT, when this card is 50/75% faster.
Message edited by Alatriste on 07-03-2008 at 01:09:30 AM
Reply to Alatriste
- 0 +
We aren't comparing the 7600 GT with the 8600GT. We're comparing the 8600GT with the 7900GS.
Here's a good example from that article:
http://www.techspot.com/articles-info/51/bench/CoH.png
It's fairly clear which one is faster here...
And in Far Cry, even more obvious results:
http://www.techspot.com/articles-info/51/bench/FarCry.png
Message edited by cjl on 07-03-2008 at 01:12:24 AM
Reply to cjl
- 0 +
I agree, I saw that OC on your 8600 and did a double take. Despite the good cooling and being stable on 3Dmark, it is still very possible that your RAM is frying, or got fried, especially with a hefty OC like you have (especially since I believe you said that you have had crashes even after installing the Zalman).
Because I consider 3Dmark a "quick stability test". It will basically show you if you have gone waaay too far. However, IMO, it is not in any way a good stability test beyond just a "quick test". 3Dmark only runs for a couple minutes, then takes a break loading the next scene, then the gpu gets a pretty long break during the cpu test. The card never truly gets tested like it would if you were playing Crysis for 2 hours. Not even close.
You really want to stress your card even more than your would likely ever stress it while gaming. As for how long, my rule of thumb, since I never game for more than like 80 minutes straight, is to be stable under the worst circumstances for a good 2 hours. If you game for 2 hours max, then stress test for 3. Better to be safe than sorry. Plus if you OC truly is stable, nothing will go wrong, you'll pass the test no problems.
Also, since you are having problems. I think you should run a stability test on everything and see if you don't get any errors. You have a C2D, so grab the latest Prime95, run 2 threads, and run stress test in blend mode for a few hours.
If all that goes well it is much easier to assume that your aren't having a hardware issue.
However, with your gpu, I suppose it is possible that your core is running fast and cool, no problems (hence the high fps you get), but perhaps your gpu memory has taken some damage and is starting to go. I've never been a big fan of gpu coolers that totally ignore the RAM. Sure it doesn't get as hot as the core, but if you are an overclocker it is definitely something you shouldn't ignore. All the 3rd party coolers I get cool the RAM as well. One being the good ol' NvSilencer 5 on my old 7900GT (best 3rd party cooler ever).
I think what you need to do first is reinstall drivers, as mentioned, if you haven't done that. In fact, I would suggest, just to be safe, uninstalling the old drivers, then restarting (as you normally should do anyhow), then clean out all your temp files and clean your registry. Or maybe use some driver cleaner software. Then go ahead and install the new drivers. That way you can pretty much eliminate drivers being the issue. Also try older/newer drivers, something other than what you are using now.
After that, do the basics. Defrag, scan for viruses/spyware/adware, clean your registry, temp files, and I even manually go through my startup menu & services just to make sure nothing funky is going on there. If still having problems, a repair install of the OS often does the trick. Better yet, if you can do it easily enough, just do a fresh OS install.
Also, if you have TRULY stressed the crap out of your gpu and haven't turned up any issues, I would also highly suggest running an entire system stability test. I'm talking grabbing the latest version of Prime95, run 2 threads, and do blend mode. Run that for a few hours to make sure your system is stable. Btw, I would try this before doing anything more drastic like a fresh OS install, of course.
Maybe run some system RAM, cpu, and hard drive benchmarks to see that everything is performing up to par as well.
So there is all sorts of stuff you can do. However, if still have problems after trying most or all of the things I mentioned, I would have to assume there is a problem with your graphics card. Something that you likely can't fix.
I suspect memory simply because, from my past experiences, every time I've had stuttering in a game but at the same time had high FPS, the vid RAM seems to always be the culprit. Not that there is a physical problem with my vid RAM, but just that with some cards the RAM specs just aren't enough to keep up with some games at good resolutions, high settings, and some AA tacked on.
A good example of this is oblivion. Oblivion can really stress your vid RAM with the way it renders so much stuff from so far away. Even with my 8800 GTX there are some parts in the game, when outside, that I would get a little stuttering even though the fps are decent. So I'm assuming maybe something similar would happen if your vid RAM was damaged, except it would be a far worse case of the stutters like you are having.
I don't know, I'm not a super expert. Just keep troubleshooting or get a new card.
Reply to robx46
- 0 +
Just saw that you did in fact format your HD and reinstall OS. If still problems I would highly suspect your card having series issues.
Reply to robx46
GABA is the main component of the medication Pagaclone. I see that it is available in GNC vitamin store. Does anybody know how much you have to take to get the therapeutic effects??
Reply to Anonymous
There are 1868 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Difference in these cards is only the factory OC right?
By fantastik250, 28 minutes ago:
I should say that is the only difference.
Best offers
Top experts
