Tom's Hardware > Forum > Motherboards & Memory > Memory > wintec memory problems
Forum Motherboards & Memory : Memory - wintec memory problems
I have a Compaq Presario 2104us notebook and was only running 256megs of shared memory. I decided to upgrade a little and bought a 512meg p2700 wintec stick. AMPO 33amd1333N-512M-R. The 256meg chip is also a P2700. When I installed the new chip with the old also in place laptop just keeps powering up and shutting down, I had to pull battery to stop it. Wintec replaced chip and now it doesnt shutdown but chip is not recognized by xp or in bios. I took my old chip out and it started shutting down again. I have tried installing in both slots and it makes no difference. Has anyone ever had same problem with Wintec?
Sponsored Links
I have Wintec memory for desktop 4 gigs DDR. I did run memtest when I got them and they were fine. I did not mix and match stuff though. I even got a mild overclock with them. run memtest with each stick seperately.
Reply to maximiza
- 0 +
system just keeps shutting down immediately after turning on. can't run test.
Reply to wop283
There are 1240 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
