Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Looking for a small upgrade... need some help
Forum Motherboards & Memory : General Motherboard - Looking for a small upgrade... need some help
Hey everyone, first time user here. I am looking to upgrade my PC soon and would like some advice.
So I currently am running an AMD FX-57 with 2 Gig RAM, and dual SLI 8800 GT OC on a A8N32SLI-Deluxe Mobo
I was to finally make the move to Dual Core and am looking into the Q6600 for is OC'ing ability... I don't want to go extreme but maybe around 3GHz
Since I have the Graphics cards already does anyone have a suggestion on a Mobo with Nvidia SLI that is good for the Q6600...
I am looking to spend around $400 total.... CPU i can get for around $150... let me know what you guys think!! THANKS
Sponsored Links
Make sure you stay away from any TR revision of EVGA 680i SLI's as they can't run the 45nm quads and they cannot OC any quad CPU worth a darn.
Reply to hesskia
i would recommend either a 750i or a 780i board. i don't think you need the performance of a 790i.
Reply to Nik_I
750i is more stable, so take that one, also its way less expensive.
Reply to Physicz
eVGA 750i: $180 after shipping and rebate
Q6600 retail, $195
http://www.newegg.com/Product/Prod [...] VGA%2b750i
http://www.newegg.com/Product/Prod [...] 6819115017
or
GIGABYTE GA-M750SLI-DS4 AM2+/AM2 NVIDIA nForce 750a SLI, $154 after shipping
Phenom 9850 BE, $194
http://www.newegg.com/Product/Prod [...] 6819103249
http://www.newegg.com/Product/Prod [...] 6813128339
I'd just forget overclocking, it's pointless with these CPUs and games. Only if you play FSX, otherwise they won't be used at 100% even at stock.
Message edited by aevm on 08-08-2008 at 05:01:11 AM
Reply to aevm
There are 850 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
