News
New virtual memory tools, devices may speed up Windows Vista I/O
When Microsoft group vice president Jim Allchin - who has since been promoted to co-president - demonstrated a handful of Vista-related projects emerging from the company's Core OS Group laboratory, perhaps too few details were provided for anyone, including Tom's Hardware Guide , to get a clear and complete picture of what these technologies are, and what they'll do. Read more
Did Intel rig its integrated graphics chip demo against AMD?
Intel's demonstration of its G965 integrated graphics chip at the Game Developers Conference in San Jose was impressive, but was it a true comparison against AMD's discrete graphics cards? Now AMD is claiming that the test of video playback against the company's ATI discrete X1600 graphics card could have been misconfigured. AMD representatives told TG Daily that their graphics card should have performed much better and offered several explanations. Read more
Samsung launches 32 GB Flash disk for mobile computers
Samsung is first to announce a Flash storage device that aims to completely replace the traditional hard drive in some mass market mobile computers. The 32 GB solid state disk (SSD) drive comes in a 1.8" form factor and reads data at more than twice the speed of hard drives. Best of all: The SSD is promised to consume 95% less power than a hard drive. Read more
Boosting SSD Performance With The Right OS
Which version of Windows will help push your SSDs to maximum speeds? Nothing you’d be able to find in the stores right now! Read more
Latest Reviews & Articles
Perfect Notebook Storage: Seven 2.5” 500 GB Drives
We compare the latest 500 GB notebook drives from Fujitsu, Hitachi, Samsung, Seagate, Toshiba and WD. Seagate is first manufacturer to reach 500 GB at 7,200 RPM, but which is really the best drive? We loaded up our updated test system to find out. Read more
Mainstream Graphics Card Roundup
You don’t always need the fastest graphics card around. For somewhere between $135 and $235, you can game like crazy in DirectX 10 without a problem at 1920x1200. We test and compare five graphics cards from this mid-range price segment. Read more
USB 3.0 Ups Peripheral Bandwidth
The new USB 3.0 interface is just about ready. It'll accelerate throughput from the 480 Mbit/s of today's USB 2.0 to 5 Gbit/s, which is important for storage and peripheral devices. But USB 3.0 also introduces power saving options. Read on for more. Read more
Your 64-Bit Check List: Potential Issues You Might See
Hardware and software support for 64-bit operating systems is available, but the full 64-bit reality may still cause you some distress. We created a short summary of things you need to take into account before installing a 64-bit OS for the first time. Read more
All the Reviews & Articles
Tom's Hardware > Forum > Motherboards & Memory > Memory > How do you know if your memory is running at the correct speed?
I recently bought http://www.newegg.com/Product/Prod [...] 20-227-178 for cheap (35 dollars) - I used to have a 2gig stick 6400.
Sponsored Links
Install CPU-Z and look. :)
http://www.cpuid.com/cpuz.php
The "DDR" in a memory's designation means "Double Data Rate", so the correct speed is half the number that follows. So DDR2 800 should read 400 in CPUz, etc etc etc.
------------------------------ Being requested to remove my siggy implying some people here would receive greater personal benefit from a local Prostitute than from a new GPU in no way, shape, or form changes the aforementioned opinion.
Reply to Scotteq
O i was scared because it showed 533MHz so you just double that because it's DDR2 right.
Reply to ragingazn628
That 533MHz... what program told you that? Cuz if it was CPU-Z then you would have an effective DDR2 rate of 1,066.
Reply to hairycat101
will a 1200 make a difference from a 1066? My processor is Quad Core 6600 2.4GHz
To be honest, I am not sold on the fact that he is running 533 MHz from his ram... What program is reading that figure?
read up. it is actually running 533x2 so 1066 which is the ones i bought
Woah wth...under the SPD in CPUZ it says slot 1 running at only PC2-5300 and slot 3 only PC2-5300... is this normal? shouldn't it say PC2-8500??!
this is what it shows for the timing tables
http://i33.tinypic.com/260zwnk.jpg
How come CPUZ says my system is running underspeed? lol CPU is supposed to run at 2.4ghz but only running at 1.6 and ram at 1066 but only 533 can someone help me?!
Not sure there is really any help for your kind, but here goes. Your ram is running at DDR2 1066. Your CPU is running normally. They throttle down to conserve energy. Basically, it drops the multiplier down to reduce power consumption. That is fine. If you overclock it, then you should turn that off in the bios.
Ditto. Speedstep, next time you build read before you get started.
Reply to roadrunner197069
Your ok Raging___, all is cool with your system
Reply to bobbknight
ok thanks I was freaking out for a second. But let's say if I run a game then it will run at max speed right?
Yes, the game will run at full speed. The Speedstep feature will only drop the speed of your processor when it's not needed. When something is using the processor, it will run at full speed. When the processor is not being taxed, it will slow down to conserve power.
Reply to jmacfarlane
There are 1158 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
