Tom's Hardware > Forum > Storage > Flash Media > Wanna buy portable harddrive.Help required.
Forum Storage : Flash Media - Wanna buy portable harddrive.Help required.
I am plannig to buy a portable harddrive of minimum 320 GB and your help is required in selecting best brand.THANKS!
I-Omega 320 GB : 3550 INR 3 yrs warrenty
A-DATA 320 GB : 3200 INR 1 yr warrenty
Seagate 320 GB : 3650 INR 2 yr warrenty
Seagate 320 GB (another model) : 4000 INR 5 yr warrenty
Transcend 320 GB : 3600 INR 3 yr warrenty
Sponsored Links
cant you get a western digital, i hate recommending anything else
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
- 0 +
Or you could get a good external enclosure and a really nice quality hard-drive to put in it, like a Western Digital Black with a 5-year warranty. That way you can choose virtually any size you want.
Reply to leo2kp
Yup! But WD is too costly starts from 4000 INR.But I have budget of 4500 INR and I was thinking if I could get 500 GB harddrive in this budget.I have heard about Transcend and Seagate other then WD but not about other two.If I could get a brand similar to quality of WD then I will look for 500 GB harddrive otherwise WD.THANKS!
Reply to RohanGenius
But won't it be inconvenient to carry.Harddrive + USB extension + Cable.Also there are chances that it might get damaged during handling.If you could tell me a external harddrive which I could use as internal (for PC or Laptop under my budget) also then it would be very helpful.THANKS!
Where are you people?
I bought a 250GB Maxtor external HDD package a year ago and is working very well until now. I highly recommend it.
Reply to rodyhoffer
There are 1074 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
