Tom's Hardware Forums » Graphic & Displays » Graphics Cards » Half-life 2 episode 2 gaphic problem
Word :   Username :
Bottom
Author
 Thread : Half-life 2 episode 2 gaphic problem
Profile: stranger
More Information
Hello
When ever i open hl2 epiosde 2, some objects like desks chairs rocks are dim and grey. So, what should i do in order to fix this problem.
Thnx
Related Product
LVL: ????
Profile: old hand
More Information
Maybe that is their color? Try taking a screen shot so we can help you more. Try updating your video card drivers.
Message edited by pcgamer12 on 06-23-2008 at 08:23:32 PM
I'm proud of myself,because i'm from IRAN
Profile: Forum Veteran
More Information
Hello and welcome to the forums mate :)
Have u updated the drivers?
Do u have this problem only in HL2 ?
Q6600@3.4,SAPPHIRE HD 4870X2,OCZ 4GB DDR2 800 RAM 4-4-4-15,ASUS MAXIMUS FORMULA X38,SEAGATE 500GB 7200RPM 32MB,TT V1 CPU Cooler,TT ARMOR SILVER ALUMNIUM With 25cm FAN,OCZ MODXSTREAM 900W,LG 2284F 1680x1050
Profile: stranger
More Information
Well I have a service pack 2 XP professional version, when I used XP service pack 1 last year in HL2 EP. 1 it worked, but now I dont have the xp sp1 system which I dont even have,
More Information
I think u misunderstood me :)
I said have u updated the drivers (VGA Drivers)?
Profile: stranger
More Information
CONTINUED... HL2 ep.2 has another problem as well like when Alyx speaks, her lips don't move. here is an image of the dim objects...
http://rapidshare.com/files/124517757/jjj.bmp.html
Message edited by kookoob on 06-23-2008 at 09:00:55 PM
Profile: stranger
More Information
Try reinstalling the game....and make sure your using the newest Video driver Catalyst if you have an ATI card or Forceware if you have an Nvidia card
PC- AMD 5000+BE 3.1ghz, MSI K9A2 Platinum, 2x Shappire 3870, 4gb Corsair XMS, ABS Tagan BZ 900w, WD 74gb Raptor, 500gb Seagate, ThermalTake Shark Case
Profile: Faithful Poster
More Information
When i first installed that game it more or less insisted i update the drivers and when i did it acctually made the game look worse. I ended up having to go back a couple of drivers to get one that worked properly. My issues did include the lack of lip movement and i could see the wire frames in peoples heads.
mactronix
Profile: stranger
More Information
Well, I dont no how to update the drivers, please tell me how. However, I have an ATI card which I bought 3 years ago. This poblem occurs only in HL2 Ep. 1 and 2 and probably HL2. When I used windows xp service pack 1 the problem was not there until I use Windows XP service pack 2. Unfortunately, I dont have an xp service pack 1 here :(
Well where are the VGA drivers? Please explain in details step by step so I can fix he problem.
Thank you,
Message edited by kookoob on 06-24-2008 at 04:23:42 AM
More Information
What is the model of your VGA?
Tell me and i will give u the link to download it
Profile: journeyman
More Information
Mazier our proud receptionist :) .
More Information
Thanx alot mate :)
Profile: stranger
More Information
I dont know how to figure out the model of my VGA. Please tell me how to check it in oder to tell you the model and from that give me the link.
Thanx
More Information
1_Right Click on desktop >>> Properties>>> Choose the "Settings" Tab>>> under the "Display" You will see the model of your VGA
For example mine is NVIDIA GEFORCE 8800GTX
2_Another way is this:
Click on Start>>>Run>>>Type: "Dxdiag">>>Choose the Display tab>>> And you will see your VGA name in front of "Name"
Profile: stranger
More Information
oh ok thx, its NVIDIA GeForce FX 5200
More Information
Download this and see what happens:
http://www.nvidia.com/object/winxp_175.19_whql.html
Profile: journeyman
More Information
