Tom's Hardware > Forum > Storage > Hard Disks > Can i speed this up
Can i speed this up
Forum Storage : Hard Disks - Can i speed this up
I have a SeaGate st3320620as 320Gb sata2 hard drive on a gigabyte 8ipe1000 rev 1 main board and it is running very slow do i need a driver or anything to speed it up abit?
Sponsored Links
It sounds like you have something misconfigured.
Reply to jsc
Welcome to the forums!
Could you be more specific as to exactly what is running slow?
A quick look at Your Motherboard shows that your system is prety dated.
Perhaps whatever apps/games you are running simply require a better CPU or GPU to give adequate performance.
Please post back the specifics of your issue along with a complete list of your systems hardware.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
^+1 on the oldness. It's a socket 478.
You might also want to check for viruses, malware and trojans and defragment to get a little more speed.
Reply to evongugg
It isn't really really slow its just my old IDE hard drive was nearly as fast and i only recently brought this hard drive, I just want to speed up the transfer rate heres my current speeds from HD Tune 2.55
Transfer Rate
Minimum: 10.3Mb/sec
Maximum: 76.6Mb/sec
Average: 61.2Mb/sec
Access Time: 14.1ms
Burst Rate: 104.0Mb/sec
CPU Usage:28.9%
Main board Gigabyte 8ipe1000 rev 1
CPU Intel Pentium 4 2.6 Ghz
RAM 1.5Ghz (1x 1gb, 2x 256mb DDR)
Graphics Nvidia GeForce 6200 (256mb)
Hard Drive SeaGate st3320620as 320Gb sata2
running on windows xp professional Sp3 5.1.2600
Message edited by danielbw on 09-23-2009 at 10:51:05 AM
Reply to danielbw
Those results from HD Tune are not bad at all considering the board you have the drive connected to, but your CPU usage is really, really high. Now, it could be that old CPU just needs to work that hard, or you could have a lot of background processes running.....which on your system with the amount of RAM you have, is going to really have a slowing down effect on everything.
Defrag, see if you can shut down some of your background processes.
Reply to jitpublisher
Those numbers are a bit slow, but not too far off given the drive and board.What were you expecting with a 2-gen old (actually 3-gen, since the 7200.11 series spanned two generations internally at Seagate) hard drive?
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
There are 401 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
