Help, What is AUX, is mine overheating??
I just built my new comp and i downloaded speedfan to keep an eye on the cpu heat, and my cpu's heat is fine but my "AUX" is at 122. Is this normal or is something overheating. Please help.
Specs:
ASUS P5KC AiLifestyle Series iP35 Socket 775 8 channel audio ATX Motherboard
Intel Core 2 Quad Q6600 (Not Overclocked)
Nvidia GeForce 9600GT
OCZ 4GB ram
3 answers Last reply
More about help mine overheating
  1. Its nothing. Mine does the same thing. The most inportant part in SpeedFan is the TJCase, CPU, Core 0,1,2 and 3 and MB.
    The AUX is not anything and your system is not overheating.
  2. download hardware monitor instead its better : http://www.cpuid.com/hwmonitor.php
    AUX could be excluded from the active sensors list if it is stuck to a specific number and has not moved.
  3. ok thanks
CPUs Heat
