I'm running this corsair. its default setting was 800 5-5-5-18 on 1.85v and runs fine.
I changed it to the rated setting of 1066, 5-5-5-15 on 2.1v. I ran memtest and it gave over 4000 errors over 9 hours. It will boot to windows, but causes errors so that scandisk runs and finds errors.
I'm running on a EVGA 780i mobo.
Am I doing something wrong? Or should I RMA it? Thanks.
Do you have the latest bios from EVGA loaded? Also, have you tried increasing your memory controller voltage? You may a little more SPP aka memory controller voltage to run at 1066 vs stock settings.
------------------------------Official Corsair Tech Support. If You Need Help, Just Ask.
Reply to XMSYellowbeard
