G
Guest
Guest
I've recently decided to construct a mid-range homebuilt gaming rig (my first) and... well, I want some advice on these parts I've picked out. Basically, I'm looking for possible alternatives that may be better suited to my intended usage for the computer and budget, which is... oh, 1,300 USD. Anyway, the parts I have my eye on are as follows...
Motherboard: DFI LANPARTY DK P35-T2RS LGA 775 Intel P35
http://www.newegg.com/Product/Product.aspx?Item=N82E16813136043
Processor: Intel Core 2 Duo E7200 Wolfdale 2.53GHz 3MB L2 Cache LGA 775 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115052
Yes, I do plan to overclock. One possible alternative I've considered is the e8400. I know the difference at equivalent speeds is decidedly minor, but... that difference is most pronounced in gaming, if I recall.
GPU: MSI NX8800GTS 512M OC GeForce 8800GTS (G92) 512MB 256-bit GDDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127325
There's a very strong possibility I may hold off on purchasing a new GPU, since the HD4870's are right around the corner.
HDD: Western Digital Caviar SE16 WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Heh, 640 GB is a bit much for my purposes, since... I have a 250GB on my current machine and I've only got about 150GB of that filled. Still, the price was decent for the size of the drive.
Case: Cooler Master 690
http://www.buy.com/retail/computers/product.asp?loc=692&sku=206177908&wl=1
RAM: Patriot Viper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220293
DVD Burner: SAMSUNG Black 20X DVD+R 8X DVD+RW 12X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 20X DVD±R DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
DVD-ROM Drive: ASUS Black 16X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135151
Operating System: Microsoft Windows XP Home With SP2B 1 Pack - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116056
Other Stuff: Arctic Silver 5 Thermal Compound - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
As for power supplies... well, I'm a bit torn between two particular ones.
The CORSAIR CMPSU-650TX 650W ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005 ) and the PC Power & Cooling S61EPS 610W ( http://www.newegg.com/Product/Product.aspx?Item=N82E16817703005 )... they might be overkill for what I'm planning on buying, but I'd like to carry over whatever PSU I buy this time into the NEXT computer I build, whenever that may be.
One last thing... I was initially planning to keep my current monitor, a VA1912wb 19" Viewsonic with a native resolution of 1440x900, since it still works great and would save a good deal of money for me. However, the Acer AL2216Wbd Black 22" 5ms Widescreen LCD monitor ( http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094 ) has caught my eye and would provide me with a larger screen and better resolution (1680x1050). Think I should just keep my current monitor and save 200+ dollars or buy the Acer?
TOTALS (Assuming I don't hold off on the GPU)
-Without the Acer: 1029.88USD before mail-in rebates & shipping
-With the Acer: 1,259.87 USD before MIR & shipping.
Anyway, any input/advice on my build would be great. Thanks in advance.
