Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Possible compatibility issue?
Forum Graphic & Displays : Graphics Cards - Possible compatibility issue?
This could be one of the stupidest questions ever...but here goes...
AMD just released their 4850, which I bought, will an AMD GPU work with my new Intel CPU (E7200)?
Sponsored Links
As long as your motherboard has a PCI-E slot your good to go.
------------------------------ Don't go away mad, just go away!
Reply to techgeek
As far as chipsets go as long as you have the correct slot on the board PCIE or AGP if its an older system (obviously not in your case) then the only thing you need to worry about if you want to run more than one card is if the mobo supports SLI or Crossfire. SLI for Nvidia cards Crossfire for ATI/AMD cards. But if you dont have any plans to run more than one card then either will work.
Mactronix
Reply to mactronix
There are 1122 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
