Hello all. After many RMA's and then a step-up, I finally got my computer running for about three weeks now. I have my Q6600 OC'd to 3Ghz and my system is 99.99% stable. However, if I try to take it above this, my video doesn't boot. The system doesn't give me an error (EVGA 750i FTW Mobo. It beeps when it fails to post.) but the monitor simply doesn't boot. When I set everything back, it works fine. I've tried changing the multiplier to get the FSB to 1600 and the CPU to 2.8 which did allow my computer to boot up, but crashed seconds after vista booted up, so I didn't try that again. Any help in finding the source of this problem would be appreciated.
What voltages are you using? What temps are you getting? What frequency are you runnning your RAM at with that overclock? What do you mean your monitor doesnt boot?
Message edited by irkjab on 04-25-2009 at 09:48:13 PM
------------------------------Q6600 @ 3.2 | Xigmatek HDT-S1283 | ASUS P5Q PRO | XFX GTX 285 | 4gb Corsair DDR2-800 | Corsair 620HX PSU | Creative X-Fi XtremeGamer | WD 640gb | Vista Ultimate 64-bit
Reply to irkjab
Sorry for the slow reply. I messed with voltages a little, but don't remember if I ever increased them past what was needed for 3Ghz. My temperature is about 33-38c, depending on the core. Memory is still running at 1066.
EDIT: Monitor doesn't wake from it's standby mode. When it's on and after twenty minutes it shuts off, that type of standby mode. That's what I mean by "doesn't boot".
Message edited by killerzuchini on 04-28-2009 at 02:13:46 PM
I had the same issue when I overclocked my Q6600, but it was at around 3.7ghz. I thought it was faulty hardware but it turned out that the machine wouldn't POST because the memory clock was too high. I set my memory to Linked Synced (cant remember exactly what the setting is I'm not at home" and then proceeded to up the FSB using the auto settings. I notice you are using 1066 RAM. Try some DDR2 800mhz RAM and try going over 3GHZ. I'm guessing it will work.
