Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Should I start with CPU water cooling?
Forum Overclocking : Cooler and Heatsinks - Should I start with CPU water cooling?
In the process of building a new PC based on a i7 920 and dual GTX285's
I'm looking at doing a water cooling setup with the following:
(Don't have all the part numbers on hand :P)
Triple Rad (Looking at the Feser at the moment)
3x Noctua Fans
CPU block (Swiftech GTZ)
1/2 inch ID tubing (Feser as well, maybe a smaller ID?)
Pump (Looking at suggestions)
Reservoir
That should be sufficient to keep my CPU cool, obviously I'm looking for a maximum OC so I'd keep the triple rad designated to the CPU.
Question, should I add a second loop to cool the 285's? I'm a relative noob to watercooling, so I'm thinking I should start with the CPU and possibly add the GPU loop down the road.
If I do go with a GPU loop what are the benefits to a full cover waterblock vs a waterblock + ramsinks? Any suggestions?
Sponsored Links
It is my opinion that the system you are looking at would be great, but very, very expensive. Especially if you add waterblocks to your gpus. I don't know if you already have the two 285s, but from a cooling standpoint you might be better off with a single gtx295...you won't be too far off in performance from the two 285 cards, and it will get much better airflow, so you won't need the water cooling. Plus it will save you about $400 - $600. As far as cooling the cpu I think you should look at a single self contained unit like the Coolit Domino...They keep my 4.0 ghz i7 920 overclocks to low 50s under max load....if you really think you need more than that you could step up to one of their models with a bigger pump and radiator. The Domino can be found for under $100, which would save you at least another $300 - $400 from the setup you are looking at designing.
Reply to belial2k
CokenBeer, your on track, perfect. That rad will give you great CPU temps.
And yea, you'll need a seperate loop for the two GPU's, they generate a lot of heat. Enough they would effect the CPU loop if you added them. You'll need a 120x3 rad.
Any stay away from the Coolit stuff.
Your very close to my setup I'm building. Linky.
http://www.ocforums.com/showthread.php?t=604016
Reply to Conumdrum
Thanks for the replies :)
I'm in the process of ordering everything, and I think I'll order 2 EK waterblocks and a second triple rad :D
http://www.ncix.com/products/index [...] r%20Blocks
Those should work real well :)
Would I require a second pump for best results? Or could I run them all on a single pump? Any suggestions for pumps?
This is what I'm looking at atm, but I can always order from another supplier if there are better suggestions!
http://www.ncix.com/products/index [...] e=Swiftech
Reply to cokenbeer
One more question for people! I know certain Radiators work better with a high CFM fan and others work well with lower CFM (like the Noctuas).
What's suggested for low CFM?
Reply to cokenbeer
^The question is do you mind a bit louder fan (+ rad combo) if you get better temps?
See rad testing here:
http://i4memory.com/wp/martins-liquid-lab
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
Probably gonna go with the Feser X-Changer rads, they're expensive but seem to offer the best performance.
Also seems that they work well with a lower RPM fan Noctua P12 is what I plan on using.
Any cases which will allow me to put both loops internally :D? If not I'll get a radbox and mount one in the back!
Reply to cokenbeer
Look at mountain mods for really big options on cases. Lots availible and easily ones for 120x3 times two.
You only need one pump per loop.
Reply to Conumdrum
There are 655 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
