Greetings all,
I continue on my struggles to get this new computer working. It is absolutely driving me nutts, and I am hoping some might have some insight on what I could try. I recently purchased a
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
with
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118019
as the cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16811103010
As the case
and
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
As the motherboard. I have a 10K RPM Hard Drive (raptor), 4 sticks of 240 pin 1 gig sticks of RAM, and a 650 Watt Power Supply that are used from my old computer. Once I put the computer together I found that nothing happened when I hit the power button. No beeps, no fan turns, nothing. I continued to test with a different computer and found that the power supply worked fine, as did the 8800 GTX video card, and the hard drive. I took all sticks of RAM out, still got no power, and put 1 stick of RAM back in, and still got no power. I assumed it was a DOA motherboard as I do not see how a bad processor would cause the entire motherboard to not even turn on, so I RMA'd the motherboard. They were out of stock, refunded me, and I then purchased a
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188013
To upgrade it a bit and ensure this didn't happen again. Well it just arrived today, and upon putting the computer together I find that the *exact* same problem remains, I see no evidence of any power going through the motherboard. The motherboard has 2 onboard "power on" and "reset" buttons, as well a BIOS code indicator that seems to me, should get power and turn on if the motherboard was getting power. I am unable to get this motherboad to turn on either, and I am wondering if maybe it is the processor ( which is going to put me in a real bind as I've had it for almost 2 weeks now dealing with all the back and forth shipping ).
I know the power supply works as it works on my other computer, but I do not have a spare intel processor to test the motherboard with, so I am unable to change out the processor for another processor, or the motherboard with another motherboard to test either of them. I have taken out all of the RAM, and still nothing happens when pushing the on-board "power on" switch. Any insight on further tests I can do to ensure it is the processor, or to get it working would be very appreciated, as I am having difficulty believing that I was shipping 2 different DOA motherboards, and I am going nutts trying to figure this out, thanks!
with
as the cooler
As the case
and
