Tom's Hardware > Forum > CPU & Components > Other Components > Acer Aspire 5682WLMi Display Problem
Forum CPU & Components : Other Components - Acer Aspire 5682WLMi Display Problem
Hi,
I've got a problem with my Acer Aspire 5682WLMi Notebook. When I start the notebook the screen is more or less black. I can see the Acer logo in the background though when it passes the bios....just very faint. As if the image is there but the light isn't. When I connect it to a normal monitor it works perfectly. I've tried setting the contrast but it to no avail. Anybody know a solution? Should I open it up and check any loose connections or should I send it to Acer? (it's not under warranty anymore). I am not a qualified PC technician and do not want the repair to be expensive!
Thanks.
Sponsored Links
Seems like the backlight died. You'll need to have it serviced.
Don't know how much it will cost to place though. Go to a few PC repair shops to get price quotes. If I had to guess, maybe $100?
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
Thanks, I read that a Lid Switch could be a problem but don't know the location. A friend told me that it might just be an inverter thats conked off and not the backlight itself!. Not sure what is....I live in Tokyo, Japan
Reply to emailgmohan
Yes its probably an inverter problem.
We can rule out that its a software issue since its having the problem even in the bios, and we can rule out that its the video card itself since when you hook up to an external screen it works just fine. It's a screen issue.
------------------------------ Gigabyte GA-P35-DS3L*Intel E2180 OC 3.00Ghz Lapped*PowerColor ATI 3850 256MB*Patriot 2x1GB DDR2 800*Cooler Master CM690*Western Digital 250 GB*Silverstone Strider 600 Watt Modular PSU*Samsung Lightscribe Drive*CoolerMaster Geminni II Lapped Mirror Finish
Reply to SuicideSilence
Right, I agree with you.
any idea where the Lid Switch is located for Acer Aspire 5672WLMi? Just to cross check.....
1) What could be the total cost of repair? and 2) is it better to be serviced by Acer Japan (expensive) or at a local PC repair shop(unsure of expense)?
am now thinking of connecting my laptop to a TV/external LCD monitor and wonder if this might work out cheaper?
Im not sure on the whole lid switch is located, but i can tell you that it would probably be better to have you local pc repair shop fix it for you. They are probably much cheaper and do the same quality work.
Message edited by SuicideSilence on 07-23-2008 at 10:18:25 AM
Thanks, I'm heading over to PC Depot shop here...meanwhile, it will help if there is any updated information.
There are 601 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
