Oops!! Maybe THIS would help! :-(
Last response: in Cell Phones & Smartphones
Archived from groups: alt.cellular,alt.cellular.nokia,alt.cellular.nokia.ringtones,alt.comp.sys.palmtops.pilot,comp.sys.palmtops (More info?)
Have you got a Nokia 6600 and/or Nokia 6230 and a Palm device, that you wish
to connect (telephony, data wise)?? (bluetooth is NOT an issue).
Then you may need a driver for your phone, so that it can communicate with
your Palm device??
Tough.. There isn't one!!
I am aware that others have had a similar response, but the more that
communicate with Palm, then MAYBE we stand a chance??
Mailed Palm the other day, and this was their response.
Dear ....
Thank you for contacting palmOne Technical Support. Your case number is
We would like to inform you that a phone driver for mobile phone models
Nokia 6600 and Nokia 6230 have not been developed yet by palmOne due to the
low number of requests received. Your query has been transmitted to our
developers for their information.
If you wish to manually set up a GSM/GPRS connection please refer to the
following articles on our knowledge library. Please use relevant article for
you.
PalmT OS 3.3 - 3.5 handheld
Solution ID: 7802, How to configure a GSM Internet connection over Infrared
PalmT OS 4.x handheld
Solution ID: 7803, How to configure a GSM Internet connection over Infrared
Solution ID: 7805, How to configure a GSM Internet connection over
BluetoothT
PalmT OS 5.x handheld
Solution ID: 7807, How to configure a GSM Internet connection over Infrared
Solution ID: 7806, How to configure a GSM Internet connection over
BluetoothT
If you wish to manually set up a GPRS connection for your mobile phone
driver please refer to the following articles on our knowledge library.
PalmT OS 3.3 - 3.5.3 handheld
Solution ID: 7799, How to configure a GPRS network connection over Infrared
Solution ID: 7800, How to configure a GPRS network connection over Infrared
Solution ID: 7808, How to configure a GPRS Internet connection over
BluetoothT
Palm.. Wakey Wakey!!
More about : oops
"Kevin I Chapple" <kevinx@NOTTHISBITearthling.net> wrote in message news:<cisopu$prg$1@news7.svr.pol.co.uk>...
> your Palm device??
Why do you need a driver- can't you simply set up a generic infrared
modem connection? I'm not a Palm guy- I'm writing this on a Pocket
PC, but with PPCs you just set up a dial-up connection using the
Generic IR Modem settings and off you go.
Besides, wouldn't a driver be the responsibility of the phone
manufacturer? If I buy a peripheral that connects to my home PC, it
comes with the drivers (if needed)- I don't ask my PC manufacturer for
them.
> Nokia 6600 and Nokia 6230 ...
> following articles on our knowledge library...
Well, did any of them work?
If you can manually setup the connection without any trouble, then no
special drivers should be necessary.
As a Palm stockholder, let me tell you they need to do a lot of "wakey
wakey" on more important matters before worrying about a few lousy
phone drivers! ;-)
Archived from groups: alt.cellular,alt.cellular.nokia,alt.comp.sys.palmtops.pilot,comp.sys.palmtops (More info?)
On Wed, 22 Sep 2004 22:10:35 +0100, "Kevin I Chapple"
So, how about flooding them with requests?
Chris Pollard
CG Internet café, Tagum City, Philippines
http://www.cginternet.net
Tried setting manually, and no they didn't work.
PPC's (as I am sure you are aware) DO indeed work differently.
"....on more important matters rather than worrying about a few lousy
drivers".
May I suggest you read some of the posts, Tony. I am NOT alone in this
frustration. Yes I am sure Palm have other "pressing developements" to be
getting on with, but this "small, insignificant" issue is all part of the
big picture, don't you think?
Thanks for the feedback anyhow.. !!
"Todd Allcock" <elecconnec@aol.com> wrote in message
news:D e37a2e0.0409222015.73e9634f@posting.google.com...
wish
with
> > your Palm device??
> them.
> phone drivers! ;-)
Related ressources
Should have course read "Todd" and not "Tony", in my posted reply below.
(Would have thought I'd have more important matters before worrying....) !!
news:cj2e1d$av6$1@newsg4.svr.pol.co.uk...
> drivers".
you
> wish
> with
> > > your Palm device??
> > them.
models
the
> > phone drivers! ;-)
"Kevin I Chapple" <kevinx@NOTTHISBITearthling.net> wrote in message news:<cj2e1d$av6$1@newsg4.svr.pol.co.uk>...
But other Nokia IR phones do? Not to be a wiseguy, but are you sure
your settings are correct- i.e. do they work with other Nokia models?
True, but generally they are as ornery (if not more so!) than Palms.
> drivers".
> frustration.
I don't doubt it, but myriads of other Nokias communicate effortlessly
with Palm devices. If Nokia has done something different with these
models, I don't think that's PalmOne's fault.
Maybe it's part of a secret plot to make you all frustrated enough to
buy Treo 6xx's... ;-)
A few years ago I had a Nokia 7160 that simply wouldn't connect to the
newer (at that time) Pocket PCs (but connected to older Pocket PCs
just fine!)
After screwing around with different settings and registry settings
for weeks and spending countless hours on the phone with both Nokia
and Microsoft, I threw in the towel and changed phones.
That Nokia 7160 was also stubborn about conecting to Palms as well.
Somebody wrote a script for Palms to connect to that phone (I remember
it because I tried using the concept on my PPC to no avail)- maybe a
Google search might turn it up and it may be adaptable to your current
problem.
Good luck!
Sure do Tony....
Works fine with my (shelved) 3650, and also with the 6310i (a hardy
workhorse :-))
PalmOne claim there is not enough "interest", but they "may" release the
driver soon.
I HAVE tried with other phone settings, but no joy.
(s'pose I could of course keep my 6310i to hand, purely for Palm
connectivity use, but "Nahhhh. I don't wanna do that!".
Thanks anyhow for your "constructive" feedback this time :-))
Cheers
news:D e37a2e0.0409261926.5e023ce3@posting.google.com...
> > drivers".
> > frustration.
the
> just fine!)
> problem.
> Good luck!
Sod it. Done it again!
Sure do TODD.... NOT Tony!!
Sorry about that (again)
news:cja4n5$713$1@newsg3.svr.pol.co.uk...
> Sure do Tony....
> workhorse :-))
> driver soon.
> Cheers
> > > drivers".
> > > frustration.
> the
> > just fine!)
> > problem.
> > Good luck!
"Kevin I Chapple" <kevinx@NOTTHISBITearthling.net> wrote in message news:<cja58d$5dv$1@news8.svr.pol.co.uk>...
No worries- "Tony" makes me sound cooler! ;-)
Christopher Pollard <rubbish@cginternet.net> wrote in
news:alg4l05l7hasjmqp0qrl3394gmndd9nlov@4ax.com:
> about floo
No way, at least in the European server because they ask for your name and
your phone's data.
Once they know you from the 1st time they will know it is flooding.
I mailed them 3 times, they answer was the same...not enough demands, etc.
After then my mails were unanswered.
Maybe we should flood their server...
Nokia 'enhanced' the AT command set on this phone.
Ask the community
