Tom's Hardware > Forum > Overclocking > CPUs > Strange Q6600 Problem
I have a Q6600 with a big Zalman heatsink on it, OC'd to 3.0GHz. Idles at just under 50 degrees and goes up around 70 degrees under 4 threads of the P95 Small FFT test.
This is all fine and well, and were the numbers I was shooting for. However, (and it seems to happen randomly), the computer will boot and both CoreTemp and CPU-Z will show that the multiplier changed from 9 to 8, and the CPU is running at 2.6GHz.
I'm relatively new to overclocking, so maybe this is a common problem.
Any ideas?
Sponsored Links
Its called speedstep and it changes from 9 to 6.
Reply to daship
Its not a problem,there is a feature in BIOS called speedstep,when enabled your CPU downclocks in idle mode so the multiplier changes from 9 to 6,disable it if u want to OC
Reply to Maziar
Oh my lord, not another one.
Ever think about maybe reading your mobo or cpu manual?
Geeesus, this question gets asked here 10 times a day and the answer is right in the friggin manual.
------------------------------ P965/Q6700@3.2 8MB HD4850 OC Edition
4GB Corsair XMS 800
Vista64/Win7
Fatality 550w/Antec 300
Reply to zipzoomflyhigh
It's not changing it to 6, it changes it to 8.
And Speedstep has been disabled the whole time :/
It's a dice roll every time I boot to see if I'll get 8 multiplier or 9...
Message edited by whpz87 on 05-01-2009 at 09:19:35 AM
Reply to whpz87
[quotemsg=1798888,4,370033]Oh my lord, not another one.
Someone's off their meds.
Reply to ram1009
There are 1115 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
