Check signal cable
  • Cable
  • Windows Vista
Last response: in Windows Vista
January 20, 2013 12:50:11 PM
Hello,
I have a Black screen and it reads check signal cable. which cable do I check?
More about : check signal cable
February 1, 2013 12:28:48 PM
Well, it says check signal cable, so I guess that's the cable you check.
You want more help, you gotta post more info.
m
l
February 5, 2013 2:02:27 AM
We're assuming you actually have the computer tuned on right?
Is it ON? Lights flashing, making happy fan noises with no beeps?
The cable would be the one going from the back of the monitor to the computer.
m
l
February 10, 2013 3:12:07 AM
jeffnvonnie said:
Hello,
Do you have a video card installed? If you do then you may not have switched your Bios to Onboard or PCI graphics and that may be what's causing you to not have picture.
If you don't have a video card then make sure that you're using the correct cable from your monitor to your PC. I'm currently using a VGA cable (blue rectangle-ish port) but there is also HDMI, DVI, and S-Video to choose from on some PCs. The signal cable is the video cable.
If you are using a TV or a monitor with multiple inputs then make sure that you have your monitor/TV set to the correct channel/input.
m
l
