Memory Problem ? ?
Forum Motherboards & Memory : General Motherboard - Memory Problem ? ?
I recently added another 2 gig of memory in mys system to take it to 4 gig all up...same brand and type...however when I open up Gigabyte "Easy Tune 6 " programme and go to the memory section it incurs an error screen and shuts down the programme...also when I open up CPu-Z I don't think it's reading all 4 memory sticks correctly as some are showing at 5-5-5-18 and they a re 4-4-4-12 sticks...
These are the ones...http://www.corsairmemory.com/_data [...] 6400C4.pdf
I have gone to the bios section and set the memory section to "manual and input those timings as the standard profile shows it at 5-5-5-18 and increased the voltage to 2.1 from 1.8 where it is at the moment however it doesn't boot up into windows properly after...
If I leave everyhting standard it does and XP does recognise 3.25 g of memory but I want to run these at the level they're supposed to be made to run for...
System specs
e8400 @ 3.0 ( 9 x 333 )
4850 gpu
500 g HD
650 True power PSU
Gigabyte EP45-DS3L M/B
PS I get better scores by in 3dmark 06 using the easy tune function on the motherbard to overclock than if I turn it off and overclock thru the bios...
Sponsored Links
If it's 2 sticks of ram, it doesn't have to be at 2.1v. 2.0v/1.9v may work as well. If the ram is set at tight timings or faster speed(o/c'ed), vdimm should be higher than stock/standard.
Write it to a disk & boot it up before you hit the sack:
http://www.memtest.org/#downiso
Reply to auscanzukus
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Memory Problem ? ?
There are 690 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
