Looking for some help picking out designing a build optimized for reduced noise with good airflow on a budget. Haven't done this in a while and the techs seem to have evolved quite a bit so I need some help figuring out what best suits my needs.
As for cases there seem to be two main designs, ones with the PSU on the top and those with them one the bottom. The idea of putting the PSU on the bottom seems kinda wierd to me for several reasons. For one, its fan is gonna be sucking right out cold air comming from the bottom. Secondly since the fan ain't really doing anything good for you its just wasted noise that needs to be compensated by additional fans. I guess on the plus side you can vent to the cpu and exaust directly out. I really don't understand why this is any better then ducting to the cpu and then venting to the exaust to the psu fan.
Next question I have relates to how you set up the CPU cooler with the ducts and exaust. With these new cases with ducts on the side panel seems like the vent would work best with a cooler that blows onto the CPU. However the more popular coolers seem to be the ones that blow air perpendicular the CPU. So basically whats the best way to pair one fo these with the duct and exaust?
Some of the cases I'm looking at at the Antech 300 which seems to have good ventilation but also has the PSU on the bottom. The Antech SOLO which is supposed to be quiet but lacks a side vent and may be too small for me. Mabey the Cooler Master Elite 324/5 which again might be too small for me. Also looked at some of the Sunbeams like the Freezing Storm.
Planning on a Radeon 3450 and Arctic Cooling Glacial 7 or possibly a Xigmatex 1263. Things I want for the case are front filter system, at least front and rear 120s, and possibly side CPU duct and less importantly a vent near the GPU. Looking to spend at most $80 if anyone has any good suggestions.
