Hi Everyone,
I am new to the forums here. My brother swears by the help on this board. I am a big computer lover. I will be honest for a couple years now I have been out of the loop on PC equipment. I want to get back into PC gaming big time, as those are my roots. I have put together a build I need help reviewing. I want to keep the price around the same. Also I am not dead set on microATX. If I have to go up a bit to get a better bang for my buck, I am willing. If there is a better deal to save me money that would be even better. Thank you all in advance for taking the time to help me with this. I greatly appreciate it.
Apex TM-302-2 Black / Silver Steel MicroATX Mid Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811154052
GIGABYTE GA-G31M-S2L LGA 775 Intel G31 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128078
EVGA 640-P2-N829-AR GeForce 8800GTS SSC 640MB 320-bit GDDR3 PCI Express x16
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130317
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148262
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model BX80562Q6600
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186134
As for the Power Supply I am not sure what to get.
Thank you all again.
Edit - Also to specify this build will run me about $700. As for gaming I want to play a lot of the new games. Crysis would be nice but I won't get my hopes up.
