I have a ASUS p5q se plus mobo with 4 GB of ddr2 corsair XMS2 RAM plus the E5200.
When I try to overclock to just FSB 250 X 12.5 with just 1.25 core voltage it doesn't present me any errors. But After I apply new specs and reboot, the PC sometimes reaches the desktop then displays a blue screen or some other times at OS loading it presents me the blue screen which reads that it will begin memory dump. Then I need to manually reset my PC to be able to use it. This only happens when I try to overclock. If everything is left as is it runs perfectly.
I am guessing that the DDR2 RAM'S need to be overclock as well to balance the CPU's overclock. But I really don't know how to begin.
I assume your ram is ddr2 800? If so than with e5200 at stock, fsb : ram ratio is set to 1:2, giving 400mhz(ddr2 800) memory speed. When you raise the fsb to 250 memory speed becomes 500mhz(ddr2 1000), and that probably causes your system to crash.
I tried overclocking at 250 FSB but still no result.
I decided to try a lower FSB like 224 and it worked. No blues creen or anything.
I noticed something rather odd. I check with CPU-Z and it is showing me the my RAM timing is 5-5-5-15 when manufactures specs say its 4-4-4-12. Is this the problem that is causing me not to reach FSB 250?
Also I looked for FSB:RAM ration setting in BIOS and could not find it. Also used CPU-Z to see the ratio and found out that its at 3:5. I'm guessing that this might have something to do with the problem at higher FSB.
These are the settings I have:
2.8 GHZ
224 x 12.5
PCIE --100MHZ
Core voltage -- 1.26v
RAM Voltage -- 2.1v (specific manufacture voltage)
Look, if you read the guide everything will become clear. You wont find Ratio Setting in bios, those different memory speeds you can choose from are your ratios. With fsb 250, memory speed of 250mhz(ddr 500) is your 1:1 ratio , and you should set it to that when overclocking CPU, to prevent overclocked memory from causing problems.
You can change timings manually in bios to those specified by manufacturer, theyre not always set correctly by the mobo.
Looking at the settings you posted, I can tell that your problem at this point is probably your vcore.
I could try explaining what to do here, but I think it would be alot better to just refer you to the stickys. Most of the answers to your questions can be found in there, and if after reading through that you still have questions, you can come back here and we can help you from there.
While reading the stickys, you should note that the BIOS on a motherboard will vary from one manufacturer to another, so settings might be labeled differently than what you might be looking for.
Exactly.
And bios shown in the guide is Amibios which you have on your mobo too, so its pretty much identical
I got a problem. I overclocked it to 3.0 GHZ and it starts off fine. But after a while It restarts with no error message or blue screen or anything that would tell me what is wrong. It just restarts.
I up dated bios because in previous motherboard I installed a new processor and it would restart just like that and all it needed was a BIOS up-date.
