Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > How big of a power supply would I need?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - How big of a power supply would I need?
This is what i'm using right now
http://www.newegg.com/Product/Prod [...] 6817371011
I just put a 9450 intel quad core in, 2x2gb ocz ram, visiontek 4870, also have 1 dvd-burner, 250gb hd, 74gb raptor in my system.
What would I need to get upto 4x2gb ram, another 4870 xfired?
850watt or higher, I believe 650w is too low for what i want to do eventually.
Since the 4870s seems to max out at 285w by itself under load.
Thanks!
Sponsored Links
[url]http://educations.newegg.com/tool/psucalc/index.html
Reply to cmichael258
A good 750w PSU will be plenty, I recommend the PC Power and Cooling 750w, it is the absolute BEST 750w PSU when it comes to stability and quality.
Reply to The_Blood_Raven
jpbg wrote :
http://www.newegg.com/Product/Prod [...] 6817139006 same as the pc power and cooling but cheaper^
TY! I did not know that psu calc existed. :D
Reply to stonezippy
do u plan to upgrade ur system in the future?
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
It just depends. If I added another 4870 and 4 more gbs of ram, i'd be maxing out my system. I want this rig to last around 2.5-3 years.
It depends on what the prices do of those 2 items.
Reply to stonezippy
I've got the Zalman 750 (yes a 750 should be plenty)(I just hate the blue LED's), and I'm using a 9850 (high wattage) it runs my system fine. Just get a good quality PSU, and it should last you through a few builds.
P.S. Modular cabling is a plus
Reply to IH8U
[quotemsg=1843761,7,55670]Another, slightly different approach to PSU selection,
is to look at their graphs of efficiency vs. load.
Then, pick a point on that graph where efficiency
is highest: in that way, you'll minimize power
consumption in the long run.
Whenever in doubt, a good rule of thumb is
to utilize 50% of the rated capacity of any given PSU.
Interesting... when looking at the Corsair efficiency for a 650 W supply:
<http://www.corsairmicro.com/_images/charts/tx650w_efficiency.jpg>
The 230 Vac curve is 2% higher than the 115 Vac... Perhaps I should consider running a 230 Vac line to my server to get the better efficiency! Has anyone else out there considered this?
Reply to ksweitz
okay so i would suggest a good 600watt. im running a q6600 oc @ 3.0ghz and 2 gtx 260 in sli oc running on a 500w! just to be safe i would recommend 600w if ur gonna oc alot or if u add any extra hardrive, fans etc..
anything above 700w is just overkill.
Reply to invisik
There are 728 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
