Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Water Cooling Kit without backplate
Forum Overclocking : Cooler and Heatsinks - Water Cooling Kit without backplate
Hi there is a Water Cooling Kit without backplate?
Sponsored Links
AFAIK no.
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
I did a search and I found one without backplate (NorthQ Siberian Tiger II Water Cooler) but I am not sure if it is good for cooling my q6600 3.6GHz also I have room temp 33C. :sweat:
http://www.driverheaven.net/review [...] 4&pageid=1
The problem is that I have a small form factor case and the big air coolers don’t fit inside so the Water Cooling Kit is my only option (because i can place it out side the case) if I want to have my q6600 OC at 3.6GHz.
Reply to michaelmk86
^Right! Most of the after market kits (ie TT,etc) are about the same as a high end air cooler (ie TRUE 120). How ever, there are some high quality kits namely from Swiftech.
See:
http://www.swiftnets.com/products/h20-220-APEX.asp
There are 947 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
