Hi guys, here are my specs to start with:
570W TRUST PSU
ASROCK PENRY1600-110DB SLI X 3
1 X ACER DVD RW DRIVE
300GB SATA WESTERN DIGITAL HD
5 PC CASE FANS
6GB DDR2 800- SHOWING UP AS 533 IN BIOS
Q6600 2.4GHZ - IDLE AT 55 -60 DEGREES
LEADTEK 9800 GX2 - IDLE AT 52 DEGREES
Basically I built this system, everything is new apart from the psu, I had to buy adaptors to power my GPU as my psu didnt have them. I think the pc was underperforming .
Today I tried to turn the pc on and the led fans flickered quickly then went off in an instand. Tried again then nothing , still nothing, tried once more then they flickered again. I put it down to the PSU as I have shorted the 2 wires that turn the psu on and it does the same thing.
My question is would it have damaged any other of my parts, if it has then im a dead man. It cost me and arm and leg to build.
Also would this psu me ok for this setup.
Corsair TX750W Specifications: Model CMPSU-750TX
AC INPUT 90-264V ~ 10A 50/60Hz
DC OUTPUT +3.3V +5V +12V -12V +5Vsb
MAX LOAD 24A 28A 60A 0.8A 3A
MAX COMBINED WATTAGE 180W 720W 9.6W 15W
TOTAL POWER: 750W
Thanks guys
570W TRUST PSU
5 PC CASE FANS
TOTAL POWER: 750W
Thanks guys
