Here is my problem: I recently had a new sound card installed on my computer (Sound Blaster X-Fi Xtreme Audio), running Vista Home Edition, and consequentially purchased a new headphone/microphone to use with this new card. I mainly use the microphone with games and Ventrilo. What is happening is that as soon as i plug in my microphone jack, i can hear myself everything i do in my headphones. When i unplug the microphone the headphones still work, and i can hear everything fine, such as music and other noises, so i believe that the problem is originating with my sound card and the microphone.
I have played around with everything in control panel's and have run several diagnostics, to no avail. Any help in this manner would be greatly appreciated.
Additionally, i purchased the Ritmo ST-860WM headset, if this is of any further help.
there is a checkbox somewhere that turns that off, i think it is vista rather than creatives panel. under advanced, but my computer is down so I can't help u find it. I remember unchecking it once.
------------------------------E8500,GA-EP45-UD3R, 8 GIG MUSHKIN, XFX 4890 , ASUS 22", WD 640 X 2, CM 532, CM 650TX
Reply to royalcrown
Thats called Feedback. There is a setting either in windows, or your soundcard drivers, that lets you turn that on and off. Check the microphone audio settings and check or anykind of loop or feedback option that may be checked.
I have searched high and low for the microphone audio settings which would allow me to turn off looping or feedback. i cannot for the life of me find where it is located, if its even where it "should" be. Unfortunately i am still stuck
In the playback devices, select your speakers, then properties. You can go to the levels tab, and scroll down until you see the mic. Check the mute box and that should take care of that.
------------------------------I suffer from A.D.O.S.
Attention Deficit..... OOOOOOH!!! SHINY!!!
Config : Vista X64 + XtreMusic + Koss SB45.
To reply on your topic, i have the similar problem (cf in french : http://forum.hardware.fr/hfr/Windo [...] m#t2814010 ).
To resume, when i start my headphone, i listen my voice into.
In reality, when i start Vista, i haven't the problem, this appear when i launch " record of sound device" in french is : "Périphérique d'enregistrement "
You can see her :
