My asus P5Q-e Motherboard's BIOS does not show "cpu ratio setting" under AI tweaker menu aswell as it does not show the same option in the advanced>CPU configuration menu.
Yes, I tried changing AI Overclock tuner to [manual]. no help...
Yes, i tried older and newer( i am using the newest ATM) BIOS softwares.
i have 2x2GB 800 Mhz Corsair memory and Intel Pentium 4 550 processor(3.4 Ghz).
Someone please help me out, cause i really have no clue .
I've got exactly the same problem on my P5Q Deluxe. I simply don't have the CPU Ratio setting in my bios even though it should be one according to the manual. I'll post here if I find out what the problem is.
