Heres the situation. I put together a new pc and still have yet to successfully power on all the way. Heres the specs.
evga 750i mobo
intel q6600
bfg 8800 gt oc
ocz 1010 w power supply (72w over 4 12v rails)
4gb ocz 1066 ram
2x lite-on multi-drives
500gb wd sata hard drive
Heres what ive tried.
reseating everything
switching psus
running outside case on foam surface
running barebones (cpu, minimum ram, gpu)
reinstalling heatsink and reapplying thermal paste
results
The only way i can get anything to run is with gpu not installed. Everything else runs fine without. With gpu installed without 6pin power everything runs but i get expected beeps. With everything installed board lights flash and fans spin up but promply cut off within 2 seconds. Sounds like a bad graphics card but i have yet to hear back from bfg as they dont pick up phones or email back it would seem. Any input or other ideas would be much appreciated
PSUs with multiple 12V rails have fallen out of favor and can cause issues with newer video cards. You want a PSU with a single beefy 12v fail.
Could also be the motherboards, nVidia's Intel chipsets are craptacular.
Edited for clarity.
Message edited by shadowduck on 06-13-2008 at 04:58:51 AM
------------------------------Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Reply to shadowduck
Did you plug in the AUX 4/8 pin connector to the motherboard?
Reply to shadowduck
Yup like i said the wierdest part is without the card in everything runs like a charm...i dont just this moment have another card handy to swap but will in the morning...would plugging just the power cable into the card with it not connected to the board hurt it to test?
Maybe Green Piece sabotaged your rig <eyes narrow>
------------------------------Robert Wilensky:
We've all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true.
Reply to HoustonSerenity
By the way never call evga phone support....theyre morons
Typical of any company that outsources tech support to India. If they are in-house and it is still that bad, well that is just sad.
Reply to shadowduck
