My budget is around $600-$750. I'm using the pc to run dreamweaver, multi-browse (loading 9-16 sites at once) and apache for php coding. The pc will not be for any gaming whatsover.
The main problem on the list is the choice of motherboard and the graphics card. The most I would ever do relating to video is watching youtube videos so I'm assuming any cheap video card ($20-$40) will do as long as it's reliable. Any revision on the list to lower the cost or unnecessary hardware? Will all the following parts be compatible with eachother or would I run into any problems when I build it?
Antec Nine Hundred Black Steel ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
Antec earthwatts EA430 430W
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371006
ASUS P5K-V LGA 775 Intel G33 ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131184
OR
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128059
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
CORSAIR XMS2 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145176
JATON Video-PX8400GS_LX GeForce 8400 GS 256MB 64-bit
http://www.newegg.com/Product/Product.aspx?Item=N82E16814139018
Seagate ST303204N1A1AS-RK 320GB 7200 RPM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148317
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151153
OR
