Tom's Hardware > Forum > Graphic & Displays > Nvidia > XFX 9600 GT Extreme Edition
I have this brand new psu http://en.wikipedia.org/wiki/PSU (TX650W) and I've installed it with my XFX 9600 GT which needs only 400
watt minimum. Every time i try loading a game, it crashes my entire
computer and it reboots itself.
My screen goes black and the monitor
goes to sleep, and the sound crashes at the same time, creating a loop
sound at whatever was being emitted from the speakers at that moment. I
was wondering if it was my graphics card that was creating the problem, but it wasn't, everything was going fine, and it
was at temperature of
115 Fahrenheit which is normal for the 9600's and
I also thought that it couldn't be it because why would the sound crash
along with it?I've also freshly installed my os XP SP2
What could the problem be?
Please respond to me because i need to use this computer very badly.
Can anyone provide me with any kind of help? Thanks in advanced.
Some spec pictures
[System Properties]
http://i254.photobucket.com/albums [...] tled-4.jpg
[CPU-Z Cache]
http://i254.photobucket.com/albums [...] tled-2.jpg
[Cpu-Z Specs]
http://i254.photobucket.com/albums [...] sign/a.jpg
[Confirmation of Gpu Temperature]
http://i254.photobucket.com/albums [...] titled.jpg
I can provide any more information if requested.
------------------------------ Need Help
Sponsored Links
Not loading a game and the PC runs fine?
Load a game = PC crashes. A specific game? or just any game at all?
Does the PC crash if you play one of the Windows games like Solitaire or Hearts?
also your links arent working....
Reply to WR2
Counter-Strike: source, a highly physics demanding game, it runs dx level 9
Team Fortress 2, a higher demanding game, Runs dx 9 as well,
I dont know whats going on, i've used several drivers and still no progress.
But i've concoluded that it will only crash at a high demanding 3d game
Reply to caution_sign
have you tried updating your bios? that probably wont fix it but its worth a try.
Reply to ilovebarny
imma go check :p
there are no updates :( what else can i do
what is your 12v rail amps? its possable that you dont have enough amps evan thought you have enough watts.
Reply to ilovebarny
your problem sounds a lot like mine:
SWF file
I have a Zotac 9600GT with a 460Watt Cooler Master.
Reply to momentkiller
its this psu, I asked in their forums and they said that there shouldnt be a problem since that psu is one of the best reliable they have.
http://corsair.com/products/tx.aspx
moment killer, thats exactly what my problem is, it happens to me in tf2, it just goes blackj and i cant pay and it may sometimes reboot itself after that
I tried running TF2 on a different pc and it works perfectly without any crashes. That leaves the memory.
What brand do you have?
****, I just tried a different vid card.. a 7900gs and TF2 ran even better than with the 9600GT.
But the strange thing is that the 'older' games don't work on my pc with the 9600GT but they do work with the 7900gs installed.
I guess the 9600gt isn't compatible with games that run on older engines like tf2. But that doesn't explain the cod4 crashes...
caution, regardless if they say if that's one of the most reliable PSU's they have, that PSU may say 400 watts, but it may not be able to power that card. For example, someone I know had a PSU that was supposed to be like 450 watts but had like 16-17 amps on the 12v+ rail. Vs I had a 400 watt at the time that had 20 amps on the 12v+ rail. Your PSU may not really have enough power to power that card. When you look at a PSU, look at the amps on the 12v+ rail mostly, not the wattage. There are many PSU's that say 600 watts or 500 watts and can't put down the power a good 450 watt unit can.
Reply to ohiou_grad_06
it says 52A on a single 12v rail-
Corsair TX650W Specifications: Model CMPSU-650TX
AC INPUT 90-264V ~ 9A 50/60Hz
DC OUTPUT +3.3V +5V +12V -12V +5Vsb
MAX LOAD 24A 30A 52A 0.8A 3A
MAXCOMB.WATT. 170W 624W 9.6W 15W
There are 1277 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
