Tom's Hardware Forums » Homebuilt Systems » New System Build » [New System Build] This is what im aiming for...
Add a reply
 Word :   Username :
Bottom
Author
 Thread : [New System Build] This is what im aiming for...
Profile: stranger
More Information
Getting ready to order some parts for a new build. I ran into these forums and have seen how much good advice you have given to everyone else. These are the things that really wet my pallet but i am very interested to see if there is anywhere i can save money on what im buying by buying another model or brand. Or if what i have right now is the bang for my buck.
SAMSUNG 20X DVD±R DVD Burner Black SATA Model SH-S203B - OEM $26.99
http://www.newegg.com/Product/Prod [...] 6827151153
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case - Retail $84.99
http://www.newegg.com/Product/Prod [...] 6811119137
Seagate Barracuda 7200.10 ST3250410AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM $59.99
http://www.newegg.com/Product/Prod [...] 6822148262
EVGA 512-P3-N800-AR GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI $159.99
http://www.newegg.com/Product/Prod [...] 6814130357
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V Power Supply - Retail $129.99
http://www.newegg.com/Product/Prod [...] 6817139006
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory $89.99
http://www.newegg.com/Product/Prod [...] 6820231148
EVGA 122-CK-NF68-A1 LGA 775 NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail $199.99
http://www.newegg.com/Product/Prod [...] 6813188013
Intel Core 2 Duo E8400 Wolfdale 3.0GHz LGA 775 65W Dual-Core Processor Model BX80570E8400 $189.99
http://www.newegg.com/Product/Prod [...] 6819115037
These are the parts i found to look best for me but wondering about the case and cooling issues. For the OC question im not sure if i am going to or not but would love to have the option to. So i want to build to be able to have freedom with the system. this is about borderline of my budget if there is a way to save money somewhere else and improve performance some where else please let me know. i have read about amd for the cheaper budget but wha ti have read and seen i am very for intel atm. please leave any comment you may have bout upgrading or degrading a piece. and maybe if watercooling is evern worth it. any thing is helpfull. Thank you for taking the time to read my post and a comment.
Related Pr oduct
Profile: addict
More Information
Got picks you got there mate!
Seagate 500GB 32MB 7200.11 is better though.
To reduce your budget but still OC capable than Gigabyte GA-P35-DS3L is your option.
Water cooling is not necessary just get Zalman CNPS9700LED.
With only 1 GPU Corsair VX450 or 550 is enough and cheaper.
The rest is fine.
AMD and Intel? hmmm......expensiver means more you get mate. You got what you've paid..so your choice there mate.
I don't wanna start AMD and Intel-fans war but right now I prefer Intel. Don't get me wrong, I am the neutral type, I have 2 systems at home phenom9500 and Q6600, both of them are good.
Intel Q6600 @ 3.0GHz + ASUS P5E X38 +
4GB DDR2 1000 CL5 Mushkin + Coolermaster Dominator Xcalade 690 + Corsair VX 450W + HIS HD 3850 512MB Turbo + Seagate 500GB 7200rpm 32MB + Zalman CNPS 9700 LED + Logitec EX110 + ASUS VW198S.
Profile: member
More Information
I agree with prev post.
Robert Wilensky:
We've all heard that a million monkeys banging on a million typewriters will eventually reproduce the entire works of Shakespeare. Now, thanks to the Internet, we know this is not true.
Profile: stranger
More Information
Thanks for the reply.. as i sat waiting for one i poked around with running sli =X.. haha oh boy so much choices is it really worth it? and if so is the setup fine for it and what vid card would you reccomend.. so many fun things to choose from!
Hiya
Profile: enthusiast
More Information
http://www.newegg.com/Product/Prod [...] 6813130098 $109.99
MSI P35 Neo2-FR LGA 775 Intel P35 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] 6835233001 $24.99 ($14.99 after $10.00 Mail-In Rebate)
XIGMATEK HDT-S963 92mm Rifle CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6835233019 $6.99
XIGMATEK ACK-I7751 Retention Bracket - Retail
http://www.newegg.com/Product/Prod [...] 0&Tpk=mx-2 $6.99
ARCTIC COOLING MX-2 Thermal Compound - Retail
http://www.newegg.com/Product/Prod [...] 6835233003 $36.99
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler - Retail
http://www.newegg.com/Product/Prod [...] 6814127329 174.99
MSI NX8800GT 512M OC GeForce 8800GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card
http://www.frostytech.com/top5heatsinks.cfm <--- Look at this please.
Ok here's the deal. Stay away from that mobo you chose. It's bad bad bad. It's buggy, and it over all sucks. P35 board ftw. The MSI board has way better cooling for the north bridge and south bridge than most boards out there right now, it's a great overclocker and it has no bugs/issues. It comes revised with all the updated bios for that cpu you chose, so you will have no need to flash your bios which is a very very good thing.
If your not going to do any extreme overclocking there is no need to waste your money on a big honking cpu heastsink/fan. That cpu you chose does an easy overclock to 3.6GHz just by moving up the FSB on it (8x400) which means you won't have to up the voltage for it which means no heat issues. Any overclock you do past the 3.6GHz isn't going to gain you enough over all to justify it unless your just trying to set records for 3dmark. The Zahlman 9700 is a waste of money. It's price does not justify it's performance. If you really plan on doing some extreme overclocking then I would advise getting the XIGMATEK s1283 I posted, but only if your going to really crank it up, otherwise the cheaper XIGMATEK I posted (top link), will be more than sufficient for what you need. No need for over kill especially with the good cooling/airflow you have in that case you chose. Also I highly advise that thermal paste (Arctic Cooling MX-2). It's non conductive unlike Artic Silver 5, it has no curing time unlike Arctic Silver 5, it last for years unlike Arctic Silver 5, and it does a better job of bringing down the temps than Artic Silver 5 not to mention it's easier to work with. I have used it in my last two builds and it's about the best thing since sliced bread.
Also after reading the reveiws on newegg it looks like that vid card you chose is having major heat issues and that's after those people used Riva Tuner and cranked up the fan speed to 100%. So that right there says stay away from that card. It's always good to read those reviews to get an idea if there is any issues. That MSI vid card is not only factory overclocked, but it has the best stock cooling system out there right now for a 8800GT.
Anyways I hoped this helped. You have a nice build going for ya btw. I like your choices other than the mobo and vid card. :)
Profile: stranger
More Information
hehe yah i wasnt to sure on the mb and vid card theres so many 8800's out there. havent built a new pc in 2 years so i kind of got out of the loop but wasnt to hard to get into it again.. i'm so happy to have found these forums. the only thing is i am interested in running sli on my system and have been reading 9600gt are best because of scaling. i personally dont know anyone who runs sli what would your opinion be from running the 8800gt or 2 9600gt's? Or what would you reccomend? i really appreciate all the comments that have been posted so far thankyou for all your input.
Hiya
Profile: enthusiast
More Information
My opinion along with the majority on here is that SLI is over rated, over priced, and makes for major heat issues not to mention Nvdea boards are buggy at best not to mention there is no real gain with SLI in most games.
If you want to spend a few more dollars you could always go with the 8800GTS (G92) 512. It's the vid card in the second post in that link at the bottom of this post.
http://z3.invisionfree.com/kips_co [...] owtopic=48 <--- You might want to take a look at this to see if there is anything that grabs your attention. I went with the E7200 on that first build just for the fact it overclocks so good for the price. I used the E8400 on that second build on that link.
Profile: stranger
More Information
Thanks Why_me you really put me a few steps closer to finallizing my order.. i really appreciate the info.. :wahoo: :wahoo:
Profile: addict
More Information
I agree with this one. The reason is that you won't receive 2x performance but you have spent 2xand used 2x power.
Butof course, for some people, performance is everything.
As for heatsink, Zalman CNPS9700 is a very good cooler but a little expensive and a little bit noisy, but I have fallen in love with the unique form from CNPS9700 and CNPS9500. I have used Zalman products for years and I am satisfied with it.
If you like Xigmatek HDT-S1283 or scythe orochi, they are also good, and if you don't have much money and don't wanna go too high, Artic Freezer pro 7 is also good.
Profile: stranger
More Information
yah there are so many pieces out there it more about what the person who is buying likes is what it mainly boils down to. we have so many options out there to choose from. i think i got all the pc info i was looking for.. one last thing i run 21 inch crt that gets 150 refresh and has an awesome picture but might be looking for something 24" lcd or bigger any suggestions.. Thanks again for the pc info was a really big help glad to get it done.. thanks again
Add a reply
Google Ads
