Tom's Hardware > Forum > Storage > Hard Disks > [Solved] Noise coming from Hard Drive
Forum Storage : Hard Disks - [Solved] Noise coming from Hard Drive
Best answer from hawkeye22.
After my last hard drive went bad, i got a new one with the RMA from Western Digital. However, when i installed the new hard drive, i hear a noise that kind of sounds like a wire hitting a fan, but a little different and it only happens when the hard drive is loading something. I brought my computer to a shop, but they told me that they tested the hard drive and that it was fine and that they didnt hear any noise. I am positive that there is a noise, and i dont know what to do at this moment. I am just wondering if this is an issue that i should be really concerned about. I think it is the hard drive because i have checked all of the fans in the case, with no wires hitting the fans, and as i stated before, the noise only happens when the hdd is loading something. This is a computer i built myself, so no help from any manufacturer..........
Download the data lifeguard diagnostics from WD and see if they turn up anything.
http://support.wdc.com/product/dow [...] =6&lang=en
Sponsored Links
IMHO It is something you should be concerned about.
Please, please do not store data of any value on this hard drive. Either buy a brand new [not refurbished or anything like that] hard drive or insist on obtaining a replacement for this one asap.............
Reply to foxy_roxy
Best answer
Reply to hawkeye22
An additional source of diagnostics, though Data Lifeguard is the most reliable and the only convincing for WD:
http://www.pcworld.com/downloads/f [...] ption.html
Reply to Pointertovoid
There are 1159 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
