Hey Everyone,
I would appreciate advice for my new build.
1500 budget
Primary uses are gaming, photo editing, watching video.
So far this is what I have come up with...
ASUS P5Q3 DELUXE/WIFI-AP CH1-11 intel p45 chipset ATX form factor 3xPCI-E(x16)/2xPCI-E(x1)/2xpci/4xddr3 w/sata2 raid,dual lan(gb),usb 2.0 & audio (cpu type:intel - socket 775)
www.mwave.com/mwave/skusearch.hmx?&scriteria=BA25040
INTEL Core 2 Duo e8400
OR
INTEL core 2 quad q9450
OCZ OCZTVEND2 Vendetta 2
www.mwave.com/mwave/viewproduct.asp?PID=CPU-OCZ&updepts=COOLING-CPU&DNAME=Cooling+-+CPU
OCZ OCZ3P13334GK 4gb kit (2gb x 2) 1333mhz 7-7-7-20 240-pin ddr3 dimm w/heat spreader
www.mwave.com/mwave/skusearch.hmx?&scriteria=BA24842
ASUS EN8800GT/G/HTDP/512M GeForce 8800 GT 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready
www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=ASUS+EN8800GT&x=21&y=31
still looking at a case, psu, and HD
Would like a case w/clear side
would like to use an LG GSA-H55L DVD from old system if possible
www.cdrinfo.com/Sections/Reviews/Specific.aspx?ArticleId=20651
and
Sony SDM-HS95P display
www.dealtime.com/xPF-Sony-SDM-HS95-19-TFT-screen-silver
All suggestions welcome....
1500 budget
OR
and
