Hey there,
Have a few questions regarding my new pc i just built.
First off the specs:
Intel Q9450
Asus P5Q P45 Intel
4gig OCZ Ram DDR2
700watt PSU
X850xt ATI (upgrading as soon as the new graphics come out)
Right I have 2 problems:
1. So i got my pc set up and running, however when I switch it on, it loads up the initial screens for the bios information etc. But then after those screens when its ***meant to*** load the XP screen, instead it has a "_" (underscore) on the top left of the screen which flashes and just stays there. I have 2 hard drives i have conntected using the 18pin cable to the motherboard. This was from my previous pc which unfortunatly stopped working. I have also a new 500gb harddrive i connected through Sata connectors.
So i messed about with the bios and set both my drives in turns to load first on boot up. However im pretty sure my hard drive 1 is the one that has my previous XP installation on it. when i load the other one it says "No installation found". my third harddrive (SATA one) isnt even recognised yet on the bios. But im just focused on getting my new system to load my xp from my old hard drive. It worked fine on my previous pc.
2. Conneciton to the CD drives. On my previous motherboard which was a DDR1 board running a AMD 3200, it had TWO 18 pin cable sockets. So before i could connect my hard drives to one 18 pin socket on the motherboard, and my disk drives on the second 18pin socket. However the new P45 Asus board seems to only have 1x 18pin sockets which is intended for the hard drives. So i'm completely stumped on what wires and what connectors to use and where in the motherboard I should connect, as im completely stumped.
So please if anyone can offer any advice or help it is most appreciated as it is quite urgent.
Many Thanks.
Intel Q9450
Asus P5Q P45 Intel
4gig OCZ Ram DDR2
700watt PSU
Many Thanks.
