News
Nvidia Smokes 3DMark Thanks to PhysX
Published on June 20, 2008
Mountain House (CA) - Nvidia's released two powerful weapons with its GeForce 9800 GTX+ graphics card: The company can now compete against AMD's brilliant Radeon 4850 graphics card on price and the company finally has an answer to ATI's dominance in 3DMark benchmarks. Read more
E-voting worries focus on failures, not fraud
Published on November 10, 2006
Major electronic voting machine problems occurred in at least six U.S. states during the country's midterm elections, underscoring that system failure, not fraud, is the biggest issue facing future races, voting-rights activists and technologists said this week. Read more
Second Wave Of Radeon 4850 Cards To Go Against Nvidia's 9800 GTX+
Published on June 24, 2008
Toronto (Canada) - AMD is preparing an answer to Nvidia's recently released GeForce 9800GTX+ card. Read more
SD cards in tight supply due to Toshiba production problems
Published on December 27, 2004
The supply of Secure Digital (SD) flash-memory cards is currently falling short of growing demand as Toshiba may be experiencing some production problems for its SD modules, according to sources with DRAM-module makers in Taiwan. Read more
Latest Reviews & Articles
System Builder Marathon: Performance & Value
Published on January 01, 2009
We’ve built, overclocked, and tested our $625, $1,250, and $2,500 performance machines. How will these three systems compare in overall performance and value? Read more
System Builder Marathon: $2,500 Enthusiast PC
Published on December 31, 2008
We’ve seen how far a moderately priced Core i7 system can take us and now we’re ready to assess the performance advantages of better cooling and a stronger graphics configuration. Will our upgrades be worth the money? Read more
System Builder Marathon: $1,250 Mid-Range PC
Published on December 30, 2008
We see how far $1,250 gets us when building a new Core i7-based system, and how it compares to last month’s similarly priced Core 2 Duo machine. Read more
SSDs Replacing HDDs Soon? Not A Chance
Published on December 29, 2008
Some say 2010 and even 2009 will be the year of SSDs. We think not. Read more
  Tom's Hardware Forums » Graphic & Displays » Nvidia » New 9800GTX system problems.
Word :   Username :
Bottom
Author
 Thread : New 9800GTX system problems.
Profile: stranger
More Information
I have just purchase a system with the following specs:
- AMD X2 6000+
- Geforce 9800GTX (512MB)
- Gigabyte GA-MA770 DS3 mobo
- Enermax 460W PS (EG465P)
- 4GB RAM
- Running windows xp
I have it hooked up to my 46" HDTV via the HMDI cable, but i'm having some issues:
1) For some weird reason when booting up the bios screen and xp loading screen the background is a bright green color.
It didn't used to be that way (it used to show up black as normal), but after the first time problem #2 happened (below) it started loading up in green every time.
The screen looks fine once it gets into windows, but it is quite annoying (and possibly a sign of greater problems?).
2) When i try to play Crysis with settings:
- Details: all medium
- Res: 1920 x 1080
It plays awesome of like 3-5 minutes (graphics look great, and really smooth, good FPS), after that it crashes.
The game kind of freezes, after mashing the keyboard for awhile it goes back to the menu, but everything is messed up and pixelated, but from this menu i can just about navigate back out of the game and into windows.
From this point windows seem to be running normally. (So PC doesn't completely crash)
I have downloaded the latest Nvidia drivers, and Mobo drivers, but this doesn't seem to change anything.
Any ideas? What should i do in order to pin point the problem?
Related Product
Profile: addict
More Information
Sounds like a power issue but you have a decent psu. Try the card in another system with a larger psu
Profile: stranger
More Information
Unfortunately i don't have another system with larger PSU lying around :(
Is there anyway to test the power usage of the system to make sure it is the PSU?
Also i'll add that i've now tested it all the way down to 1280×1080 res with all low graphic settings and it still crashes.
Message edited by dave111223 on 07-01-2008 at 11:38:39 AM
Non-conformity for non-conformity's sake is confor
Profile: enthusiast
More Information
I'd say it's the power supply, that's a fairly low wattage unit for use with a top end card. I use a 600 watt for exact same processor and motherboard but with 8800gt instead and that runs fine. Either that or a heating issue with the card.
Profile: stranger
More Information
What's the max temp the card should be running at?
After a crash i run the Nvidia monitor to check the temp and it says the card is around 63-65. Is the NVMonitor tool accurate? If so this temp doesn't seem that high?
The case doesn't feel that hot (nothing compared to the temp my xbox 360 runs at).
Assuming it is the power supplier i'm guessing the shop where i bought the PC will let me trade up for a better spec, does anyone have an recommendations? I'm not really sure how to read the PSU details, except for the Wattage. What am i looking for (no pun intended)?
Profile: enthusiast
More Information
how much amp do u hav on ur 12v rail......
x2 5600+@2.8; 2GB RAM 800Mhz; xfx 9600GT xt; 320GB HDD; 420W thermaltake PSU
Profile: stranger
More Information
I'm not sure how to read the power table, but under the "+12V" column it says "1.5A/33A" and under the "-12V" column it says "0A/1.0A"
Profile: stranger
More Information
You need a better powersupply. Get a Thermaltake, at least 500 watts but I would get 600 or more.
Profile: old hand
More Information
That's well within temp range for that card. They didn't make the card that big (+1.5" more than 8800's) for no reason...additional capacitors and such. The heatsink is huge on those things. Here is a pic of my new 9800gtx next to my old 8800gts 640:
http://i286.photobucket.com/albums/ll98/gcarver2006/img076.jpg
The Pastafarian belief of heaven stresses that it contains beer volcanoes and a stripper factory. Hell is oddly similar, except that the beer is stale, and the strippers have VD
Profile: enthusiast
More Information
OP: Your PSU has 32A on the 12v rails, which is plenty if the PSU is functioning correctly.
q6600|Asus P5K|2x2GB G.Skill PC6400|2x320MB 7200.10|8800GT SC|Zalman ZM600
Profile: newbie
More Information
carver is rite, IF UR PSU IS WORKING FINE. try ur card on some other frnds computer having a decent psu, no offence, ur psu is awesom too. but its just another suggestion. try it.
Profile: stranger
More Information
Well i call the shop, and the guy was pretty adamant that the PSU could handle that card, but to bring it in to test out.
So hopefully today i'll be able to test it with a larger PSU at the store and see if that fixes it.
BTW i fixed the green boot screen; like an idiot i had been playing around with the HDMI settings on the TV and set the color mode to YCbCr instead of RGB...
Profile: stranger
More Information
So turns out it was some kind of defect in the card.
I bought the PC back to the store, and they switched out the card for a new one, and no more crashing. Works great now.
Google Ads
