Tom's Hardware Forums » Homebuilt Systems » New System Build » New system won't power on, need help...
Add a reply
 Word :   Username :
Bottom
Author
 Thread : New system won't power on, need help...
Profile: stranger
More Information
So this is the first system I've put together completely on my own in years. I'm not sure if I'm doing something wrong or if something might be bad.
The problem is that once everything is connected and I hit the power button the green light on the motherboard lights up and the internal fans connected to the motherboard spin for a split second then stop. The fan on the power supply never even spins up for a second. I disconnected all the power cords from the power supply thinking maybe the power supply was bad (I just bought it from newegg and just opened it.) and tried turning it on with nothing attached. I'm not sure if the fan is suppose to spin up when not connected to anything but power but it didn't do anything. So I don't know if it's the PS, a short, something isn't hooked up properly or if something else is dead.
I've been using macs for the past 8 years so I haven't had to deal with building a system in ages and I really don't know what to do at this point. I'd really appreciate any help you guys could give me.
Thanks so much in advance
**edit**
Sorry thought you could tell me if the power supply sounds like the problem or not. New to this and these forums.
Specs:
Intel Duo Core E6400
Asus P5W DH Deluxe Motherboard
Corsair 2x2gb TWIN2X4096-6400C4DHX Ram
PSU OCZ OCZ600SXS 600W RT
CASE ROSEWILL R5601-BK RT
Seagate 7200.11 500gb HD
Video card is the ArcadeVGA from Ultimarc.com it's a modified ati card to be used with arcade monitors...I'm going to be using this system for a MAME arcade cabinet.
If there is any other info I'm leaving out please ask, I'm new at this and need help.
Thanks so much
***Edit 2***
Ok so the PSU fan does come on for a split second as well. Seems as if the PSU is working.
This might be dangerous but I thought it might help eliminate the possibility that the case is the problem. I removed the motherboard from the case, placed it on a cardboard box, hooked up the power supply, harddrive, power on cable, video card, ram and cpu and that's all. I powered it on and it did the exact same thing. I read on some other boards that the board should turn on outside the case and this would eliminate the possibility that the case is shorting the motherboard. So now I have that checked off. It seems like the only thing it could be would be a short somewhere else (CPU???) or its a bad motherboard (I did buy it used off ebay but it was suppose to be in perfect condition and it looks perfect...) Ugh...any suggestions???
thanks
Message edited by toddprit on 06-14-2008 at 01:05:29 AM
Related Pr oduct
Lord of the Duck Clan
Profile: Faithful Poster
More Information
Welcome to Tom's.
PEOPLE DO NOT POST QUESTIONS WITHOUT SPECS!
Seriously, its a waste of your time and ours because answering your questions are next to impossible
Please try again.
http://www.tomshardware.com/forum/ [...] ate-modode <-- Computer Builds
Success comes from knowing that you did your best to become the best that you are capable of becoming."-John Wooden
Logitech Fanboy
Profile: addict
More Information
Did you put the grounding screws in your case?
Your experience sounds identical to one of my friend's building attempts, sure enough, he did not put the grounding screws in.
Message edited by njalterio on 06-13-2008 at 10:19:49 PM
Take my love, take my land, take me where I cannot stand.
I don't care, I'm still free you can't take the sky from me.
Profile: stranger
More Information
Hmm...are those the copper lifting type screws? The manual for the case said that they were not needed because of some special design of the case, but I was thinking the same thing that it seems like a short. Would those copper screw things be the grounding screws? If not which are they? Would I have fried the system by not having them in??? THanks
More Information
He means standoffs, i have never seen a case that does not require them.
Yes copper screws you screw into the case with your fingers.
Message edited by shadowduck on 06-14-2008 at 02:47:39 AM
Profile: stranger
More Information
Well my case has raised areas and states to only use the copper standoffs for a micro atx motherboard and that the atx motherboards use the little raised mounds instead. Regardless though I tried hooking it up outside the case and I still have the same problem. Everything I've read today seems to state that there is no actual grounding going on in the case, the grounding happens through the PSU and that the case and standoffs are just to hold it in place and make sure the contacts on the bottom of the PCB don't touch metal.
So I can't figure out what is wrong. The guy I bought the motherboard from said he updated the bios in jan. and was using a E6600 which is almost the same as mine (E6400.) The power supply is defintely giving out power, the case doesn't seem to be the issue, the only other things hooked up are the ram, the cpu and the video card. I don't know what to try next and I don't know what if anything is defective or how to tell.
Profile: stranger
More Information
I hope someone can read this and offer some sort of explanation.
Here is where I am at. Tried hooking up the motherboard and psu outside of the case. Reseated CPU. Reseated ram and took out the second dimm. Removed the video card. Disconnected the hard drive. Still same thing is happening. The green motherboard light comes on, all the fans spin for a second then stop. the light stays on. Thats it. I can't figure this out.
Can it be the CPU?
The PSU?
The motherboard?
I'm guessing it's one of those things. Something isn't right. Everything has been ruled out and everything has been reseated or reconnected. There is no grounding issue. No short seems possible. So how do I figure out which one is the problem? Can it still be the PSU even though the light comes on and th fans spin for second? The PSU is 600w, should be plenty of power for the fans, CPU and RAM.
Ugh.
I really don't know where to go from here. I'd really appreciate some help or a suggestion.
Thanks
Message edited by toddprit on 06-15-2008 at 02:02:32 AM
Profile: journeyman
More Information
If you didn't use the standoffs to begin with you may have shorted the board and damaged it. Removing it from the case doesn't fix that problem. I did the same thing on my first built. I would just return the motherboard (again unfortunately).
Profile: stranger
More Information
No I am positive I didn't need the standoffs. This case has them built in (they are like raised mounds with threads that make the motherboard not touch the case) and it specifically says in the manual not to use them with the ATX motherboards. I'm absolutely positive this has nothing to do with the standoffs. If I used standoffs none of the cards would fit in the back of the case...trust me they are built into this case.
It's definitely not a short.
Message quoted 1 times
Message edited by toddprit on 06-15-2008 at 02:29:17 AM
Profile: journeyman
More Information
Wait, I'm confused now; did you use the standoffs or didn't you? I don't understand why it would say your motherboard doesn't need the standoffs, because it definitely does, but is it possible you could tell me the case model so I can get idea as to what you're talking about?
Oh, and having the standoffs doesn't necessarily affect if your expansion cards fit of not. Like I said, on my very first build I put in the motherboard without using the stands and all of my cards still fit.
Message edited by ryun on 06-15-2008 at 02:46:09 PM
Add a reply
Google Ads
News
GPS can help give early warning of tsunamis
Published on June 30, 2006
Using GPS (global positioning system) data to measure how points on land move following an undersea earthquake could help geologists decide if the tremor will cause an ocean-wide tsunami. Read more
Thermaltake PC Hardware Gets Nvidia ESA Certification
Published on February 15, 2008
Thermaltake announced recently that three new products in its PC case, power supply and cooling system lineups have recently received Nvidia ESA (enthusiast system architecture) hardware platform certification from Nvidia. Read more
A SWAN to guide blind people
Published on August 16, 2006
Researchers at the Georgia Institute of Technology have developed SWAN (an acronym for "System for Wearable Audio Navigation"), a wearable computing system to help blind people navigate in unfamiliar environments. Read more
External SATA Devices To Drop Power Cables
Published on January 14, 2008
The Serial ATA International Organization (SATA-IO) has announced that it is working on a new specification that will provide power to external SATA (eSATA) devices without the need for a separate power connection. Read more
Latest Reviews & Articles
Updated CPU Charts 2008: AMD Versus Intel
Published on October 01, 2008
The processor is the heart of your PC, and our updated charts for Q3 2008 show 54 of them competing in terms of performance. Using our updated suite of benchmarks, compare your favorite AMD and Intel CPUs after reading this introduction. Read more
Stalker: Clear Sky--Is Your System Ready?
Published on September 30, 2008
Thinking about picking up the latest update to Stalker, but not sure if your graphics subsystem can handle it? Hang on as we take you through a performance tour and demonstrate how the game has been prettied up. Read more
Part 4: Avivo HD vs. PureVideo HD
Published on September 29, 2008
The 780G chipset/Radeon HD 3200 and the MCP78S chipset/GeForce 8200 provide the first integrated graphics solutions that can accelerate Blu-ray playback. We dig deep into how well they work with high-quality Blu-ray 1080p video playback. Read more
Four GeForce 9600 GT Cards Compared
Published on September 26, 2008
Manufacturers really love the first Geforce 9. The graphic chip is fast, the cards are inexpensive, and some retailers offer more than ten variations. Read more
