Tom's Hardware > Forum > Storage > DVD/CD Writers > Nec dvd rw problem
Nec dvd rw problem
Forum Storage : DVD/CD Writers - Nec dvd rw problem
hi got a nec dvd rw nd-1300a and its not reading my dvds, i managed to read a cd, but then tried again shortly afterwards and it didnt recognise it, basically it says no cd inserted. then changed the ide cable position and this time it doesnt give me no cd inserted but just acts as if i havent inserted anything, the green light doesnt even come on now when i insert a cd/dvd, whereas on the other ide position it used to come on. good for the bin or repairable?
Sponsored Links
Check the jumpers.
Put it back on the old IDE position.
If it's recognized in the bios, update the firmware.
Do you have the latest motherboard bios?
Reply to evongugg
Try replacing the IDE cable.
Reply to evongugg
- 0 +
ok ill try these and report back, thanks
Reply to drtanz
There are 514 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
