Tom's Hardware > Forum > Overclocking > CPUs > I7 920 + ram problems overclocking?
Forum Overclocking : CPUs - I7 920 + ram problems overclocking?
I'm overclocking my i7 920 and anytime i take the processor above 3.3ghz no matter the ram settings no matter how much voltage and how low the speed is on the ram i cant even pass the windows memory test before i boot into windows but i can pass it and prime 95 @ 3.24ghz. Do i have bad ram or is it just bad for overclocking or what?
------------------------------ http://valid.canardpc.com/cache/banner/588938.png
http://www.speedtest.net/result/468703490.png
Sponsored Links
In prime 95 my temperaters don't excede 79C
My sig is with turbo mode on it just turns it back on always for some reason, i keep turning it off.
Message edited by shiftstealth on 05-16-2009 at 07:42:56 PM
Reply to shiftstealth
i ran the cpu at stock settings and took the ram up to 1600mhz at 1.65v and i got an FF error on my motherboard.
Message edited by shiftstealth on 05-16-2009 at 07:54:30 PM
Found the problem i'm not at 3.64ghz @ 1.364Vcore under load but im not sure if i should go higher because bumping it up to boot at 3.7ghz i go to 1.376vcore which is above intels recommended on newegg?
There are 953 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
