Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Catlalyst driver problem
Forum Graphic & Displays : Graphics Cards - Catlalyst driver problem
i have a radeon hd 3850 512...when i install the driver suite given with the card it runs moothly...the hitch is tat it is about a year old driver....now when i try to update it by tryin to install a newer version such as 8.3 or 8.4 it says the driver version is not compatible with the current catalyst control center...Also after installing this new driver the monitor does not display the colours properly..when i roll back to the old driver everythin becomes normal again....wat seems to be the problem???
Message edited by rahulbond2002 on 07-02-2008 at 08:39:13 PM
Sponsored Links
You may need to uninstall the previous drivers before attempting to install newer ones. In control panel's Add/Remove Programs, there should be a listing for Uninstall All ATI programs (or some such). I'd probably also recommend using a program like Driver Cleaner (in Windows safe mode)to remove any remnants.
-Wolf sends
------------------------------ System Specs:
Gigabyte EP43-UD3L Intel Core2Quad Q8400 8 Gig RAM
NVidia Geforce 8800GTS-640/Creative X-FI Extreme Music/Dual-Boot XP-64&Server2008
Reply to Wolfshadw
There are 823 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
