XQZME
12
Greetings guys! I have a problem with the PC i built. First lemme give you the specs:
Intel Q9300 2.5Ghz
Rosewill 2-Ball Heatsink/Fan
Asus P5N-D 750i
2x 2Gig Corsair XMS2
Seagate Barracuda 250gig SATA
750w Thermaltake Toughpower
2x 8800 GT 512mb
ok so heres the problem, I put everything in but when i try to boot it up, nothing shows up on the screen. Not even the memory test. I tried using only 1 EVGA and 1 RAM but the results are still the same. I tried removing all the RAM but when I did there wasn't any error sound coming from the board. Thnx for the replies guys!
pcgamer12
1,089
Try using each RAM module by itself, with both graphics cards, it doesn't matter if they are both in unless the primary is DOA. Make sure your power is on the On position (the dash - ) Make sure everything has power, 4+4 pin, 20+4 pin, 6+2 pin for each 8800GT, check for enough amps on 12v rail(s) to meet requirements for 8800GT SLI. You don't get error messages without any RAM in it because your computer needs RAM to be able to turn on a work.
pcgamer12
1,089
It could also be your power supply is DOA or isn't giving enough power if the error sound is real loud coming from your VGA card. Try 1 good card.
XQZME
12
it really doesnt give off any sound. btw whats DOA? Dead on Arrival? sorry im kinda noob at terms.. I tried the 2 EVGA and 1 RAM still doesnt work.
gadgetnerd
332
yes
XQZME
12
well all the fans, CPU EVGA are working. The LED on the board is also lit up when I turn on the switch of the PSU
XQZME
12
how does the 4/8 pin look like? coz the only connection i have from the PSU to the MOBO is the 24-pin connector..
XQZME
12
so aside from the 24 pin, i should plug in the 4/8 pin also? btw i saw the female 12v youre talking about its a 4 pin female. so should i plug it in too?
XQZME
12
thnx road! i just found out the cord you were talking about didnt come with the box. so i have to go back to fry's and ask them for the darn cord! ill keep you guys updated on what happens next! anyways thanx to all those who replied! and Happy Fathers day to all the pops out there!
XQZME
12
Good News Road! Fry's replaced the PSU and the PC is up and goin! thnx so much to the people who helped out!
roadrunner197069
Splendid
Sep 3, 2007
4,416
Alright!!!!!!!!! Happy computing. LoL, thats the first case I ever saw with a PSU that should have the connector, not having it. I wish there was a Fry's where I live. Hell I wish there was any kind of tech store around here. I got to drive 100 miles to get to a tech store. Its cheaper for me to buy online.
XQZME
12
Oh I just got another problem lol. When I start the the system, it always says " Unknown CPU. Update BIOS to unleash its full potential!". I did what the message said but when I tried to download the BIOS, it said the theres is no new BIOS for the board. I tried reseting the CMOS also but still got the same problem. Any solution for this guys?
