Hi, I don't know much about networking, but i have two computers networked via a hub. Everything is fine, I can play LAN games on them two and one can access internet via the other, but I can not access the network, I mean I had a nework set up in my last house with 6 machines and it all worked fine, it was hardly different from this one. I am running WIndows XP Home on one and Proffesional on the other. Please advise me.
Like I said the only problem is sharing and accessing the shared files, everything else seems to work.
Make sure file and printer sharing are ticked in the LAN properties box. Also make sure that the windows network firewall is off or has been adjusted to allow this kind of traffic. You will also have to do this with any other firewall you might have. Like what was mentioned before make sure each computer belongs to the same work group and has its own IP address (seeing as you can use the net I'm guessing this is all ready done but I never hurts to check).
